Cone Filters/pilot jets removal !!
  • gman
    • Mar 2007
    • 42
    • essex, United Kingdom
    Hi people,
    I am having a bit of trouble with the starting and running of my xs1100 1979. i have been told that my 4 cone filters may be adding to the trouble and that they need to be restricted by using a plate or tape accross the bell of the carbs, any thoughts ??
    Many thanks
    Gary
    UK
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    if they are a new addition, it may be the culprit and usually at 6k rpm and beyond, as some of the cheaper models out there restrict the air pilot jet, if it starting and running t may be something else, try pulling them off and starting it...
    some guru with more experience may takea stab at this when they show up.
    type in pod filters and some informative threads will pullup, good luck with it.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • gman
      • Mar 2007
      • 42
      Many thanks Mason,
      will have a look around. I think there is not enough restriction to let the floats pull up as i rev, when the engine is reving high, she seams ok !!
      Gary
      • gman
        • Mar 2007
        • 42
        pilot jets removel !!
        Hello again,
        i tried to remove my pilot jets from the carbs on my 79 XS1100 but could not move them, i read somewhere that it is very easy to damage the slot in the top, they have sat untouched ans un started for ten years.
        any ideas on the safe removel
        Cheers
        gary
        UK
        • prometheus578
          XS-XJ Super Guru (RESIGNED)
          • Aug 2004
          • 4012
          • Olympia , Wa.
          Give a small shot of penetrating oil to hopefully work down into a few threads.
          Use a proper fitting screwdriver head. I don't know it you have Sears "Craftsman" tools over there, but one of their screwdrivers in the "Precision screwdriver" set is a perfect fit. These are just cheap brass jets, and the slot can be easily ruined by an ill-fitting screwstick.
          Place the screwdriver down in the slot. Give a decent amount of downward pressure. Grasp the handle firmly, twist your wrist(taking out all the slack due to the fleshy part of your hand)and then give a real firm QUICK twist.
          After being stuck there for too many years, a quick twist will "shock" the jet loose, while a slow steady turn will deform and strip the brass slot.
          • gman
            • Mar 2007
            • 42
            will give that ago tonight, if the worst happends, how do you remove a damaged one
            Gary
            UK
            • prometheus578
              • Aug 2004
              • 4012
              • Olympia , Wa.
              "Quit drillin' me fer answers."
              Cautiously, with a reverse cutting drill bit. (which usually, after a little while, will shock the jet into spinning out on it's own)
              • red bandit
                • 955
                • central michigan
                use a #1 left twist easyout, maybe a little heat from a torch, very little, just to warm it up so you can stilll touch it with hand.
                79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
                79 SF parts bike.
                • gman
                  • Mar 2007
                  • 42
                  use a #1 left twist easyout ???
                  is this the same as a extraction tool?
                  gary
                  UK
                  • underdog57
                    • 321
                    • Alburgh , Vermont,054
                    gary
                    UK
                    Yes , same thing...
                    I dont worry too much about these jets , they are easy to get and not expensive ...but if you can save them is all the better ...
                    Bob
                    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
                    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
                      Hey there Gman,
                      Looking at the time stamps on your messages, I see this thead was BEFORE you decided to take the carbs off and clean them, and then developed a problem getting the pilot jets out!
                      If they are stuck in there, then they are probably also very gummed up, and that is probably the MAIN problem with your starting and low rpm performance, since you said it ran okay at the higher rpms, which is getting into the main jets by then!!
                      The pilot circuit and starter circuit is very suceptible to varnish and clogging. There is a jet in the bottom of the float bowl where the starter fuel line tube from the carb body fits into , and draws fuel thru, but if that bowl jet is clogged, no petrol, no start!!
                      Use a fine brass or copper wire to probe inside that bowl jet, along with spray carb cleaner to ensure that it's open!!
                      Also, don't turn the throttle when trying to start the bike, that only opens the butterflies, and drops the vacuum so that the enrichener can't pull the fuel from the bowls as effectively, less petrol, no start!!
                      I also merged this thread with your other one, since they are kinda related. It's best to keep the same problem, posts, replies, info on what you've tried, etc., in the same thread so WE don't repeat ourselves in suggesting things to try, etc.!!
                      • HobbyMan
                        MeatHead Idiot "GURU"
                        • 1801
                        • Colleyville, TX
                        I took a bad phillips head screw driver to the bench grinder. I converted it to a "thick" flat head screw driver that fits directly into the slots in the jets with no slop. Pulls them out every time.
                        Acta Non Verba
                        • gman
                          • Mar 2007
                          • 42
                          Hi TC,
                          thanks for the merge !!
                          as you described, the interior of the carb bowls and all other parts was covered in a varnish type substance ?? i managed to clean most of it from the floats, bowl and main jets but cannot yet get to the other bits, will get some carb cleaner tonight and give it a spray. I was amased how much the main jets were blocked, totally cvovered in the varnish !!
                          so near but so far
                          • gman
                            • Mar 2007
                            • 42
                            hobbyman,
                            that sound a cool idea, will try that as i have loads of bad drivers !!
                            many thanks
                            Gary
                            UK
                              jet removal,
                              Hi Gman,
                              if anything will pull a jet, this will. Grind an exact-fit edge on an old screwdriver, cut the handle off and mount the stem in a drillpress. Tear the carb down to the bare casting (you're gonna clean it anyway, right?) and hold it on the drillpress bed with the diaphragm flange downward so the jet looks up. Hold the screwdriver blade down on the jet with the drillpress feed handle and back the drill chuck around by hand to unscrew the jet.
                              Fred Hill, S'toon.
