Hi there, XS, since this is a 4 into 1 set, I am not sure what they are doing with the x overs. Generally, the xover is used to balance a dual exhaust system, where there are 2 sets of tailpipes/mufflers.
Basically, you would have to find a tech paper on the design to see what they were trying to do with those.
Otherwise, if the headpipe diameter and outlet diameter are similar, or smaller/bigger depending on your needs, it should work.
You have to remember that most GOOD 4 into 1 exhausts were designed for racing. Racing likes all the torque and HP peaks as close to the shift point as possible. If you watch Big bike racing or formula 1, they use a very small amount of the rpm range. They shift very close together.
To give you an idea, my monte has Hooker Comp series headers w/ 2 1/8" primaries and a 3.5" collector. From there it has a dual 3" exhaust with, dual chamber, Walker Dynomax mufflers and 3" tailpipes.
One would think this was plenty of pipe for the engine. However, first time I raced at the track, I walked on it off the line and spun the tires for about 20-30', into 2nd gear, before it grabbed traction.
Next run, I took off the caps (I have Y-pipes on the back of the headers, one way through the mufflers, the other straight out behind the front seats) on the same tires and spun them for 660' (mid track marker) before I let off and replanted to make it straighten up.
The first run was in the low 14's, the second in the high 17's.
First and last time on the drag strip with my street tires. With my M/T ET drag slicks I do between 12.2s and 12.4s on any given day.
Incidentally, that day I happened to do the long burnout right after Darrel Webb The Burnout King, did a 483' burnout, in his alcohol funny car, to raise money for charity...
I have a set on my 81, and I don't like anything about them. I have a set of Spaghettis, or a set of OEMs to install, just haven't decided which pipes to use.
