HAHAHAHA I laugh at you my carbs
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    OK that was a weird Title. Anyway. I finally got to the finish point on my Dad's 79F. It runs great. (soo far) I finished all of the fairing wiring and lots of electrical stuff on the bike. Adjusted the valves and changed the fork seals. Ohh yeah I changed the oil too. To the Question:
    After I had done all of this and the bike was sounding sooo great, I started to put the tank on. I always put the fuel lines on before I put the carbs on to make it easier. Well, I got everything hooked up and set the right petcock to prime. What do you know, lots of gas started flowing out of the fuel inlet on the carbs for 3and4. I thought it was a sucky hose but the fitting was moving around quite a bit, not just sliding side to side. I looks like it may even be a fractured fitting. Where do we get these? I saw a link to some nice (cheap) ones but I cant rember where or when. THanks guys.
    some times I just know this bike is just playing with me.
    Acta Non Verba
  • underdog57
    • 321
    • Alburgh , Vermont,054
    I'm pretty sure can can put new o-rings on that T ...
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
    • HobbyMan
      • 1801
      • Colleyville, TX
      what about a broken T fitting?
      Acta Non Verba
        Other than a set of used carbs, you can get a new, brass T fitting from motorcyclecarbs.com. Kinda pricy though, around $40. It has been said here that you can strip the rubber off the T fitting, and use O rings in it's place. Take a carb, and the stripped T fitting to Wesley Seals and see if he can fix you up.
        • HobbyMan
          • 1801
          • Colleyville, TX
          will do THANKS JOHN You da man.
          Acta Non Verba
