Cables and Breather Routing
  • gaffer77
    • Jul 2004
    • 444
    • gloucestershire england
    Hi does anybody know if there are pics on this forum that will show me where to route my starter to solonoid lead (as it was when it left the factory )
    The pick up leads to the connecting block
    And just basically all the leads around the battery tray area
    And there is a hole for something on the back of the crank case just in front of the swing arm ??
    I just want to get it all neat and tidied before i install the airbox and carbs ,,been building my bike for nearly a year now and it's nearing completion at last
    Can't do much more till i do these odds and ends and i am getting impatient
    Thanks
    Gaffer
    Don't put all yer eggs into one basket ,,,case
  • randy
    • Dec 2003
    • 4521
    gaffer;
    Don't know of any pictures here, but all of the wiring harnesses from the pickups, alternator and starter converge behind the fuse panel mounting bracket. Secure them with the few metal clips that are attached to the engine covers.
    The small 'hole' near the swingarm is the middle drive vent. route the hose up, it clips in to a holder at the top airbox mount and just hangs open-ended.
    The large 'hole' is the crankcase vent, that goes to the similar-sized 'hole' in the front of the airbox between carb 2&3.
    Hope this helps.
    • gaffer77
      • Jul 2004
      • 444
      That's Great Randy Thankyou
      I am happy with my bike ,,but it's not anywhere near the standard of swamp thing ,,by building this i can truly appreciate what you put into your bike and that is a ton more effort time and care than i could muster on mine !! Tho i have tried mybest !!
      Now i am off to tidy those loose ends up and get another step closer to finishing !!
      Gaffer
      Randy
      Hole in crank case is actually in the crank crase like a loop cast into the case ,,(it's not the breather cap/plate /case cover thing)
      any ideas ???
        • 7836
        gaffer77, That is probably just a locating hole for the machine work when the engine was built.
        • gaffer77
          • Jul 2004
          • 444
          Hi Ray
          That had crossed my mind ,,(used to work in foundry)
          Just wanted to be certain while i still got good access to make sure i got everything right
          That starter lead to the solonoid does it run above the swing arm under the frame ,,or over the frame under the battery tray ,,do you know ??
          Cheers
          Gaffer
          • randy
            • Dec 2003
            • 4521
            Oh, that hole in the back is a lifting hole for hoisting the motor. The starter cable runs above the swingarm. There should be a metal bendy-clip next to the lifting hole where you can secure all of those cables together.
            • gaffer77
              • Jul 2004
              • 444
              Cheers Randy ,,that's all that sorted then ,,Thankyou
