Synchronize
Hey OldYam,
Have you synchronized the carbs lately? That will help with the idle problem.
Hey OldYam,
You're probably not running much over IDLE at that speed and gear! You'll want to keep the rpms at least above 2500.
can find several tips that are NOT linked from the left hand yellow "tech tips" link by scrolling down from the MAIN FORUM PAGE to the tech tips sections and
, and crimp off once you see the timing plate rotate and plunger pull up into the vacuum pot. It should stay there. But if it releases quickly, then you may have a leak in the vacuum diaphragm. Regrettably, they are not available from Yam anymore!
Verify the hose doesn't have any cracks where it attached to the vacuum pot.
