i got the starter relay for my 82 xj100 now there is another relay that looks just like it on the left hand side. are they bothe the same type of relay and will one missing make the bike start hard
starter relay
Do you mean the 'stator'? That's the stationary part of the alternator, the winding inside the alternator cover.
Yes, you do need both those relays to activate, or wire around them.
The BATT lcd is the battery sensor telling you that either your battery fluid level is low, the connector came apart, or is corroded. It is not voltage related, but rather fluid level related.
Have you checked Troubleshooting a bike that will crank but won't start?Mike * Seattle * 82 F'n'XJ1100 *Comment
I'm thinking you didn't get the XJ specific battery, if you have to ask where the connector is, because there is a wire coming out of the cap of one of the center cells of the battery, and about 6-8 inches along that wire is the connector.
Not a problem though. You can either ignore the batt light and press the button on the lcd panel to shut of the blinking red light, or you can look in the tech tips for how to fool the lcd unit into thinking you have a sensor-type batter. It isn't involved in the starting circuit.
What is your real issue? Your bike won't fire? Won't crank? Crank but not start? If you are missing the kickstand relay, do you see the two wires that went to it?Mike * Seattle * 82 F'n'XJ1100 *Comment
Jerry Fields has a tip on bypassing the battery sensor light on XJ's, it explains the problem as well as the fix.
Gary Granger
2013 Suzuki DR650SE, 2009 Kawasaki Concours 1400, 2003 Aprilia RSV Mille TuonoComment
