Clutch Plate Bolt issues
  • BLUEJEEPLAB
    • Sep 2005
    • 703
    • Miami Valley, Ohio
    Hey Gurus,
    What is the torque setting supposed to be on the Clutch plate bolts? Reason I ask is that I just got down easy outing a clutch bolt after re-installing the clutch after the second gear fix (stole time from work this evening, I've had twenty minutes in two weeks to work on it)
    If I read the Yamaha Shop Manual correctly, it's something like 7 foot pounds. I was using a click torque wrench and it snapped the head off the bolt like butter. I wasn't even close.
    I am off to NAPA tomorrow for new bolts since it looks as if the existing clutch bolts actually stretched a little. Any one ever see that?
    Papa Gino
    79 and something XS 1100 Special "Battle Cruiser"
    78 XT 500 "Old Shaky"
    02 Kawasaki Concours "Connie"
    7.4 ft lbs is correct, but it is probably better to use a 3/8 inch deflecting beam torque wrench. The one I use is an ft lbs/inch lbs type. I have never seen steel bolts stretch when used in aluminum. I would think the aluminum would strip before the bolts stretched. Yours may have had a stress crack in it, and torquing may have been what it took to break it.
    • 81xsproject
      • 3185
      • Fortuna, CA
      you could always try this torque wrench
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
        • 5058
        HAH! Laughing my arse off!
        • BLUEJEEPLAB
          • Sep 2005
          • 703
          I could use the work out. Put all that exercise equipment to good use besides laundry rack!
          Papa Gino
          • 81xsproject
            • 3185
            • Fortuna, CA
            I didn't trust my el cheapo wrench for those VERY critical low torque apps
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • The Lorax
              • Jun 2005
              • 1048
              • Riverside, OH
              I think I used a clicker torque wrench on mine, it was in inch pounds, did the conversion...12 : 1 I think...it's been a while, worked ok for me, no issues. have a nice day and ride safe .
              I am the Lorax, I speak for the Trees
              '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
              '79 XS1100 F R (IL Barrachino)
              '00 Suzuki Intruder 1400 (La Soccola)
              '77 KZ400s (La Putana)
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                "I remember that thread, 81xsproject"
                That was great.
                  Papa Gino, what did it feel like when you were pulling on the wrench, just before the bolt snapped? 84 inchpounds (7 footpounds) is not very much at all. I wonder if a PO might have got all confused and cranked those poor little bolts up to 84 footpounds by mistake, than you happened along with the 'straw that broke the camel's back'. You say the bolts look like thay had been stretched?
                  • BLUEJEEPLAB
                    • Sep 2005
                    • 703
                    Ken, it was still pulling easy. In fact, I guess I should have been suspicious since I had hit the point where all the bolt caps were snug on the face of the throwout bearing assembly. Resistance never increased on the wrench, even after a turn.
                    At the time I thought it might have been the fact that even though I was on the face, the springs might still be compressing,
                    Papa Gino
                    • Pat Kelly
                      • 3046
                      • Golden Valley, AZ
                      After breaking one of mine I reinforced my clutch plate.
                      I drilled and tapped all 6 holes from the back (engine) side of the clutch plate. I then threaded 6 bolts in from the backside to where they would meet the star plate bolts (used red locktite). Then I cut the heads off the reinforcing bolts.
                      Now it has steel running the entire length of the aluminun post.
                      HERE is the link to the fix Maximan did. I just did all 6 of mine while it was out. When I do the clutch on my LG I'll do the same thing (and to the one I broke, as a spare).
                      Pat Kelly
                      <p-lkelly@sbcglobal.net>
                      1978 XS1100E (The Force)
                      1980 XS1100LG (The Dark Side)
                      1999 Suburban (The Ship)
                      1994 Dodge Spirit (Son #1)
                      1968 F100 (Valentine)
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        When you do the next one, we want a tech tip w/ lots of pics
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
