clutch?
  • Filter
  • #16
    If I remeber right ParTsMore friction were like 5 bucks a peice you need
    I had messed up my order then tried to reorder and they said they were out stock got lucky closed out webpage and reloaded it and it kept
    my checkout cart full. So hopefully they have som emore in stock for you
    you can also get your springs and gasket on teh same page
    • #17
      Think before you type!
      Originally posted by HobbyMan
      Do I need a new gasket?
      Do I need to REVOKE your GURU status? Sheeeez!
      The Clutch case is an oil chamber, so unless you replaced it recently and used sealant on one side, and PAM on the other, it'll probably tear up during removal. But if not, it's been compressed and heated to the max, do you really want to trust putting an old gasket back in and expect it to maintain a leak free seal??
      But, yes, recommend replacing all frictions and new springs and extra steel, and you'll be SOLID!
      • #18
        IIRC Yamaha OEM discs were around $8 from Bikebandit...
        *edit*
        I no not, in fact, remember correctly.
        Friction:$11.04
        Steel:$8.80
