Hi I have an XS 11 1981 with a modle # RS but when I order parts theytell Me that that modle does't exist. Can someone know of this model
Xs 1100 Rs
Xs 1100 Rs
81 SH (SHotgun Special)
110 mains
idle jets 2.5 turns
floats at 24mm
You live, You learn, then Die and Forget it allTags: None -
Look to your left on this page and click on SPECIFICATIONS then you will see serial# click on that and you can tell what you have by your serial #
Doug
Doug Mitchell
82 XJ1100 sold
2007 Stratoliner 1900 sold
47 years riding and still learning, does that make me a slow learner?Comment
Xs 1100 Rs
The # on the engine is 4RO-00489181 SH (SHotgun Special)
110 mains
idle jets 2.5 turns
floats at 24mm
You live, You learn, then Die and Forget it allComment
Sounds like a 1981 SH to meThe # on the engine is 4RO-0048911979 XS11F Standard - Maya - 1196cc (out of order)
http://www.livejournal.com/~xs11Comment
On the title it shows the mod # as RSOriginally posted by Snow
Sounds like a 1981 SH to me81 SH (SHotgun Special)
110 mains
idle jets 2.5 turns
floats at 24mm
Sounds like a clerk made a typo...unless that is a special European model?1979 XS11F Standard - Maya - 1196cc (out of order)
1981 XS1100SH
4R0-000101 Black Blue, Cardinal Red
Can check out serial numbers here
Hi Trapper Hey the RS on your title is the MN State code for it being a Motorcycle, RS is stamped on all 3 of my bike titles
As was stated earlier tell the parts dealer you have 81 XS1100 Special just be aware that parts are hard to find for these things depending on what ya need theres places online that
have good sources just ask and do some searching
lot of the material has already been covered
Did you get any of that snow that fell yesterday
We got about 8" up here
my '81 sh is also 4R0'81 XS1100 SH
Sep. 12th 2015
RIPComment
110 mains
idle jets 2.5 turns
floats at 24mm
Hi Ljay40. I'm new to this group and not sure how these postings work yet. We had aout 2"of snow that didn't melt. It would be nice to know for sure what model it is becouse I have gotten the wrong parts 3 times.81 SH (SHotgun Special)
110 mains
idle jets 2.5 turns
floats at 24mm
Hey Trapper,
That number from the Engine IS an 81SH, however, engines can get swapped into different frames. The frame is what is registered. The VIN # is on the side of the steering head, stamped into it on the right side. Check to make sure it's the same as the Engine #, then you will be sure you have the OEM frame and engine, and that it IS an 81SH.
Other clues are a recessed groove in the sides of the covers over the crank, the timing cover and the ALT cover. Also, remove the seat and check the TCI, it should also have the 4Ro designation. Under the timing cover, you will have a vacuum advance, but just a solid plate, no centrifugal advance mechanism....done away with in 81. The special has the front axle on the front side of the lower fork sliders, the Standard are on the END of the lower sliders. Round headlight, turn signals, gauges = Special. Square gauges, headlight, larger tank with knee recesses=Standard.
There is a link in the LINKS section that you can find by SCROLLING down from the MAIN FORUM PAGE, NOT from clicking on the Links link in the left yellow column. It's the Owner's manual for the 81H/SH, can help with basic maintainance info for you and your bike, in PDF format, ~6mb, right click and Save As!T. C. Gresham
