Just after sum advice about putting the forks
in proper alignment, i cant ride the bike past
a 100ks without a bad shimmy kicking in,
also the left side of the handlebars are dropped lower
than the right side, ive loosened the front end and
bounced the forks up and down and then retensioned
everything, but makes no difference, is there a method of checking the alignment, is there a sequence to tightening
the bolts, that is start at the bottom work ur way up or vica versa
ive also got a fork brace fitted.
any help would b appreciated
thanx in advance
thanx in advance
