Does anybody know a source for replacement rubber connectors that join the carbs to the block? (the black pieces in between each carb and the intake side of each cylinder) I have a 1980 XS 1100G and I suspect there are cracks and air leaks in those rubber manifold thingies so I want to replace them. My XS runs pretty good but it pops and runs rough a bit when cold and I suspect it's sucking air someplace. Does Yamaha still stock those or another source I could look? Thanks.
carburetors
Look in ebay...there are new ones listed all the time for around $100. A really quick fix is to wrap them tightly with elecrtical tape, and get four thermostat gaskets for an old Ford Pinto 2.3L engine, They have the correct bolt pattern, and will need just a little trimming. Use them between the boots and the head.Last edited by John; 03-30-2007, 07:18 PM. -
I plan on ordering the set with gaskets from oldbikebarn.com there price is 139.95 for the set with 9.00 shipping.yamaha dealer want 48.99 for one.
Heres the link http://www.oldbikebarn.com/motorcycl...rs&bike=XS11001980 XS1100gComment
I bought a new set for under 100 bucks on ebay and they are fine. I think they were out of canada eh."If A equals success, then the formula is: A = X + Y + Z. X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
1980 LG
1981 LHComment
partsnmore.com less than $100 shipped79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
I suspect
Most likely cracks don't go thru. (it's got an inner wall)
Can just fill cracks w/rtv, let sit over night.
Use "streathy" type electrical tape, wrap from under one clamp to other and back. from a few feet away will look good and cost zip.
Most likley not firing on all cylinders?runs rough a bit when cold
May have enricher circut issues.....
Or could be something totally different
mro
btw, just noticed your a newbe
welcome to XS land kingsdrmrLast edited by mro; 03-30-2007, 09:01 PM.Comment
