carb as always
  • chaklid
    • 22
    • mobile, Al
    carb as always
    getting good at this with you alls' help. Now to perfect things, up for the challenge??! I have got two identical '79 xs1100SFs
    One runs just superbly excellent and the other runs great execept for the following:
    tweeked the carbs; runs outstanding above 3000-3500. as i throttle back in any gear and run at below the above rpms, there is heisitation and sort of a sputter; then, when accelerating there is faltering lag.
    smells a tad rich but plugs are looking good.
    foats are at 25.7 or so, mains are 137.5; idle screws at 1.25 turns. idles beautifully; heat range all the same
    SO, what is up next????????
    Thanks y'all
    Chakli
  • audijunky
    • Apr 2006
    • 707
    • VA
    DO you have any air intake mods or 4 into 1 pipes or open headers? if so you may want to go up a size on the mains. How about a carb sync? It sounds like it is runnin rich to me?
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    • randy
      • Dec 2003
      • 4521
      Chakli;
      Have you cleaned the carbs?
      I'd suspect the pilot circuits are dirty. Also check for vacuum leaks at the intake boots and the advance hose.
