Perhaps the coils?
  • audijunky
    • Apr 2006
    • 707
    • VA
    Perhaps the coils?
    Is there anyway or has anyone had a problem with lower rpm performance( lets say idle to 3K) and the ignition coils been the problem? How about the alternator(or whatever it is called) the thing with the windings on the right side of the motor?
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    Usually, any problems in the idle-3000 rpm is the pilot circuit in the carbs. If it were coils, they'd be bad at a higher rpm Iwould think.
    • planedick
      • Mar 2005
      • 2068
      • Yorba Linda, California
      Actually yes...
      I spent weeks chasing carb problems with that kind of reaction. Really crappy running under 3 grand, wouldn't take excelleration, but when I got past 3500 it run pretty good up 'till around 6000 then crappy again. I learned lots about removing and installing carbs, but the real lesson came when I tried different coils. When you got good spark, it will run darn good at most any setting. Seeing a spark with the plug outside isn't enough. A weak spark will not work when under compression with wet gas on it.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
      • audijunky
        • Apr 2006
        • 707
        • VA
        Thanks guys, I have been screwing around with the carbs since I purchased the machine, Since I bought it and got it running it has hestated until 3k, than it is off like a rocket till redline.(around 10K I guess). I have done everything to idle circuit you can think of, even got the idle screw stuck and had to drill them out (carbs 1&2) Now in the process of putting 1 non-drilled out carb in position 1 and 1 not as bad as the one I had but still drilled out carb in position 2. Carbs 3+4 run awesome, good color on plugs nice smooth idle. Carbs 1+2 rough idle and dark plugs. I turned the idle screws in on both of them all the way to close it and the idle didnt change at all. So I figured the gas was still getting to the motor.( bad job drillin out the broken screws?) When I had it runnin I could feel the difference in the exhaust pipes 3+4 exhaust had a nice rythm at idle and no smoke. 1+2 had a sporatic rythm or no rythm at all and smoked a little. So hopefully putting in these other carbs will make difference( better)
        Thanks
        Steve
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          same crap on my bike, and now coils are inroute, the old teenage swap a new part type diagnosis, hope itr works
          plandick you said your ran bad over 6k my goes good to redline, go figure...
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • audijunky
            • Apr 2006
            • 707
            • VA
            mine also goes good to redline, So we may have a different problem than planedick..... I hope my coils aren't bad
            • audijunky
              • Apr 2006
              • 707
              • VA
              Is it possible to switch coils for diagnostic purposes? I am sure you would have to switch input wires as well as the spark plug wires. You should beable to do that right?
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                plandick was going to swap out his known good to my suspected bad, but i didn't want to ride the 35 miles with the bike running so sh*tty
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • audijunky
                  • Apr 2006
                  • 707
                  • VA
                  What I was trying to say was switching the coil for 3+4 with the coil for 1+2, since I know that 3+4 carbs and coil is good. Just trying to isolate the problem.
                  • randy
                    • Dec 2003
                    • 4521
                    audijunky,
                    the coils are wired 1/4 and 2/3. I'd venture to say that if 3/4 have good spark, then 1/2 probably have good spark. Are your 1/2 plugs clean? Sometimes troubleshooting carb problems can cause you to foul the plugs, further frustrating you. Make sure the plugs are clean before you proceed.
