how do you remove kreme from a gas tank
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    does anyone know if there is an easy way to remove kreme or gas tank liner from a gas tank?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • randy
    • Dec 2003
    • 4521
    The easiest way would be with the stuff the Kreem comes with - MEK or methyl ethyl ketone. It's nasty and messy, cancer in a bottle! But it will dissolve the Kreem liner and any rubber items, too!
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      is there a commercial product with this miracle ingredient, the po kremed the tank but, it has no rust, i heard the kreme will over time come unglued, if it stays stable then i may leave it alone, your thoughts?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • Erik the Red
        • 422
        • Northern MI
        Caveat: just my opinion
        I've heard of it coming unglued/delaminated/off/whatever. I've also heard of it never causing any problems. I did my tank last year. Probably didn't need to, but I did. My impression is that if you take care, and follow the instructions accurately, it'll be fine.
        But if you wait too long (like within minutes) between getting the acid out and Kreem in, then rust has already started to form and that's what the Kreem will bond with instead of the bare metal. If that happens, the rust will continue to oxidize the metal (while underneath the Kreem) and eventually the rust that is bonded to the Kreem falls away from the metal of the tank, and the Kreem comes with it.
        So does the PO strike you as the kind of person who follows the instructions to the letter? If so, I'd bet that your tank would be fine. That MEK is some nasty stuff, and if you like your paint job on your tank, don't mess with MEK unless you absolutely have to.
        My $0.02.
        -Do what makes you happy.
        '79 Honda CB 750 K (2)
        '78 XS 11 E - "Rhona"
        ...and a 2nd E, for the goodies on it.
        • ccogswel
          • Jun 2005
          • 302
          • Bowling Green, Ky
          I'm glad to see someone asked this question. This was on my to ask list but had been put on the back burner.
          Well anyways I bought a tank off ebay that had been lined with kreem. I don't know if the po followed the directions or what, all I can say is my kreem liner is coming off in places. I didn't know what to use to get it out. Now I know.
          mason79, in my opinion. If I was you I would go through and remove the liner as you never know what you will have in the future. And look at it this way, if you get it out now and you decide to redo the kreem liner yourself, you will know it was done right.
          Well that was my two cents. Hope no one expects change.
          Chris
          79 XS1100 Standard aka: Mutt
          Gimme Fuel Gimme Fire!
            You can get a can of acetone and use a length of chain to help loosen it. Here is a link (not well written) that might give you some ideas:
            • HobbyMan
              MeatHead Idiot "GURU"
              • 1801
              • Colleyville, TX
              Just watch your paint! I am in favor of not using tank liners unless they are really bad. Try the electrolysis method to get rust and varnish out. Just get plenty of filters.
              Acta Non Verba
                That is a fact about acetone for sure!
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  this is my oringinal tank, the newly painted one is on the bike, i would not have bought it, if i would have dismantled the original to learn of it's solid condition, only the fuel sender, was loaded with rust even that brushed clean with clr, i'm just going to bring it back to it's glory and have it around...
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • Incubus
                    • 1003
                    • Austin TX
                    If you were aking about a product that has MEK in it Mason, Home Depot sells the straight stuff. Don't spill it in your yard or the EPA is liable to list your house as a Superfund contaminated site.
                    Patrick
                    XS11F (Incubus, daily rider)
                    1969 Yamaha DT1B
                      I had to remove a Kreem liner from WK's FJ11. I asked around at some dealerships and nobody knew, so I got the phone number for the manufacturer, called them and they said to use Acetone. I bought two gallons and let it soak for a couple of days. I did move the tank into different positions to let the Acetone dissolve the liner on all surfaces. It worked great. Just be careful of the finish on the tank.
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        yeah, i question his where do i dump the mek afterwards in the las vegas' nuclear storage cave? heck i don't even know where to dump the acetone.
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • HobbyMan
                          • 1801
                          • Colleyville, TX
                          You want the easy way? Put it on an ant pile and burn it. That not necessarily the greatest idea, although I have caught myself doing that quite often. Second easiest, put it in your used oil before you drop it off at the local vat. I don't know if you should do that either but thats the only way I know how.
                          Acta Non Verba
                          • shutchis
                            • Oct 2004
                            • 191
                            • Deer Park, TX
                            The PO kreemed my Honda CB900F and it's lifting off in sheets. I was wondering how to clean this mess. So it's MEK or acetone. Here in Houston, our tanks rust; I guess it's too much wetness in the air. On my XJ700, I used a product called Porcan
                            I bought it in a kit with the cleaner, acid bath, and sealer. I took my time, followed the directions, and the results were fantastic.
                            '80 XS1100LG Midnight Special
                            Looks like an '82 Maxim, Fuel Injected
                            '82 XJ1100J, Fuel Injected
                            Stan Hutchison
                              hazadous waste
                              I just let the liquid Acetone evaporate outdoors, and then put the sludge in a coffee can, and tossed it in the trash. I don't know if that exactly envromentally friendly or not. I was living in a rent house at the time and just thought about dumpig it on a fire ant mound, but decided against that.
