Which Barnett Clutch Plates fit XS1100?
  • stevec5000
    • Oct 2002
    • 131
    • Mesa, AZ
    Does anyone know for sure what the part number is for Burnett steel clutch plates that fit the XS1100 (not friction plates)?
    Their Application Chart is wrong. It lists the part number as YP-20-20. Motorcycle Accessory Warehouse has the same error on their application chart. I ordered 7 of the steel plates from them and they are about one inch too big in diameter! Obviously for some other model. The correct ones are the same size as those used on the XS850. I need to order the correct ones but there are 2 different ones listed for the XS850 so I don't know which one to order. TIA
    72 TS185
    77 XS750
    78 SR500
    80 XS850
    80 XS1100 Midnight Special
    81 Seca XJ750RH
  • stevec5000
    • Oct 2002
    • 131
    • Mesa, AZ
    Never Mind, it fits after all!
    That part does fit! I took the clutch apart and put in the plates without any problems. It sure looked too large at first though.
    72 TS185
    77 XS750
    78 SR500
    80 XS850
    81 Seca XJ750RH
