Wandering front end.......I had the same prob turned out it was the front axle wasnt bolted up to the wheel properly....ie. it had a gap between one of the forks and the wheel hub....all i did was loosen the axle nut and the keeper bolts on the right side did up the nut on the left properly to pull the axle tight and then pushed the right fork against the ther hub before tightening the keeper bolts on the right side.....MUCH better....no more left to right wander....Cheers (just my 2 cents)
					4 (!) questions!
