Cant seem to get the low end sorted out. Still got a stutter under 3K under load. After that runs like the afterburner was lit. Feels like when you're running out of fuel, but goes away at 3.5K. Only really happens when you want to accelerate quickly i.e heavy hand.
1. Carbs are properly cleaned and balanced. I bought a 4 gauge vacuum sync, and it works beautifully.
2. replaced mains with 142.5's. Man! What a difference it makes to the power. Set the mixture screw by ear, plugs look OK.
3. My concern - There is a 3 by 1.5in hole in the airbox, and K+N filter. Too much?
4. 4 in 1 pipe.
5. Starts first swing, with full choke, but does not want to idle untill fully warmed up, thus I got to keep my hand on hte throttle. When warm, idles smoothly at 1K
A mate suggested that I close the hole in the airbox, or that I lift the needles a notch. What do you suggest?
Apart from the above, Vader runs really well
4. 4 in 1 pipe.
