Touch Clutch?
  • joshua
    • Mar 2007
    • 68
    • Tucson, AZ
    Touch Clutch?
    I just bought my first xs1100. I want to get out and ride it, but the clutch is a bear. I've checked the cable and it's not binding nor is it bent in any way. Every single pull of the clutch lever is a workout. It's like using one of those spring hand strengtheners. I could ride for 5 or 10 minutes, but then it would be too much. Any cluse as to what might be causing this?
    78 xs1100E standard
    It may not be binding, but it can still be corroded/rusted inside the sheath. Take it off, and spritz some carb cleaner down into it first, working the cable up/down or in/ out of the sheath, to work out dirt, debri, etc.. Then squirt some good lubricant in there, again working it in and out to spread the stuff into the cable sheath. Then put it back on and see if that doesn't make it easier to pull?!
      Get a new cable and if that is not the problem, you will have a spare for a road trip. If it is indeed the problem, you may have saved a tough time being stranded somewhere.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        I agree that the first thing to check is for corrosion or rust in the cable sheath. WD40 will break up the rust, but it dries too quickly, and then the cable's unlubed again. One can use WD40 or similar to break it free, but then follow with a good cable lube, like silicone, or something equally slippery, but long lasting. Disconnect the cable at the lever. Make a funnel around it, and spray a pool of lube into it, and try to get it down into the cable. DON"T make a funnel out of duct tape! The lube will dissolve the adhesive, carry it down into the cable, and when it then dries, it will really be gummed up.
        • joshua
          • Mar 2007
          • 68
          • Tucson, AZ
          Thanks. I'll try these. I know the kid that had it before me "worked" on the bike. I've found countless shortcuts so far. Is there a chance they put a wrong spring in the wrong place inside the clutch itself? I've checked the dry spring, but not inside the case where the oil is. Not sure exactly how it's built and I'm wary of just opening random cases without knowing if I need new gaskets or seals in doing so. Thanks for all the help!
          78 xs1100E standard
            You may also want to check the lever that is on the bike! The original lever has a "dog leg" in it that increased the leverage, to make it easier to pull. If the PO put on a strait lever, it would be harder to pull.
            Just a thought
            • Ljay40
              • Jun 2006
              • 149
              You may want to read this thread too its full of help on your clutch it helped me understand wahts going on
              good luck
              • joshua
                • Mar 2007
                • 68
                • Tucson, AZ
                This is the clutch on my bike. Is it the right one?
                78 xs1100E standard
                  The handle looks right, but I'm a little concerned about the angle the cable is taking out of the handle, especially since the handlebars are already turned far to the left which would usually be stretching and pulling on the cable, partially straightening out?
                  You may need to reroute the way the cable is run around and thru the Triple Tree and headlight area before it's run under the tank to the clutch case!?
                  • joshua
                    • Mar 2007
                    • 68
                    • Tucson, AZ
                    The bike now has a somewhat straight bar and the original lever was for a larger bend. That might be it. I have pics up in the member lounge. I'll see if I can angle it better and more directly.
                    78 xs1100E standard
                      I've seen your photos in the LOUNGE. All I'm saying is that you may want to route the cable around the headlight/Triple Tree area differently so that it's not put at such an angle at the bar lever holder!?
                      • 79XS11F
                        • 3563
                        • Ottawa, Ont. Canada
                        I agree with TC... and even if that's not the cause your cable is going to wear it's way into the sheath pretty quick at that location which would make matters worse. SO clean, lube and re-route the cable and you will likely be good to go
                        Rob
                        KEEP THE RUBBER SIDE DOWN
                        1978 XS1100E Modified
                        1978 XS500E
                        1979 XS1100F Restored
                        1981 Suzuki GS1100
                        1983 Suzuki GS750S Katana
                        1983 Honda CB900 Custom
                        • joshua
                          • Mar 2007
                          • 68
                          • Tucson, AZ
                          Thanks everyone. I'm going to re-route it tomorrow after it cools off. I rode it again, so it's a bit warm. I think my next step is a carb sync. It's rough, but I love riding it!
                          78 xs1100E standard
                          • malber
                            • Sep 2006
                            • 568
                            • Belmont, NH
                            Prom,
                            Might it be a good idea to take the clutch plate cover off and the cable out of that before pouring the lubricant in the cable so it doesn't run down into the clutch mechanism?
                            1981 XS1100SH
                            • prometheus578
                              • Aug 2004
                              • 4012
                              • Olympia , Wa.
                              I agree, Malber, and for you and I, you are correct.
                              I would disconnect the lower end of the cable before lubing it, just so that I can yank on the cable and see if it slides smoothly through the sheath... to see if the cable was binding, or the trouble lies elsewhere.
                              My answer was tailored around his first statement
                              I know not his ability level, and didn't want him to go messing with stuff he might be unfamiliar with, nor comfortable doing on my say-so.
                              Thank you for pointing that out.
