5 3/4 turns out on the idle and still runs bad
  • pggg
    • 1609
    • NZ
    Xs11 cams don't come on until 3 grand, especially on 78's, idle to 2500 grand is sensitive and touchy area to tune, there's a backdraft coming thru the carbs until the overlapping inlet/outlet valves 'gel' at the 3 grand mark, smooth fuel delivery and perfect balance needed with non-sticky slides, slides gotta be rising/responding smooth and even at those low revs, and no airbox/filter/intake problems, in the perfect world, setting the carbs as per stock would get the bike running as per brand new factory, 28 years of wear and tear unbalances things, also there'll be HOWLS of protest here, but ditch the inlines and see what happens, ya never know, ya can always slam em' back in if no change, yeah that idle to 2500 grand area is a sensitive one, don't be scared to tweak and experiment with different carb settings, good luck.
    • mason79
      • Mar 2006
      • 1351
      • los angeles, ca
      thanks gents i'm back, you guys hit it on the nose with the sync, lemme get over to planedicks and kick his butt for a slop job, you only get the best lovin when you dyi...
      i like pggg's pespective on things as well thanks a mil it's now 2.5 turns out plugs look good and lug top gear to 2k and takes off well
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
