to rebuild or not
  • DeanR
    • Jan 2005
    • 1493
    • Finger Lakes NY
    to rebuild or not
    I currently have a rear master cylinder somewhat apart on my kitchen table. All clean, looks great, sent a wire into that spooge hole.. This is a spare that I may use. Not aware of any problems with it but I don't know how well it had worked. The plunger is moving very well and as I said it looks great. Wondering if I need to go further with a rebuild kit, something I've not done before.
    How can I tell without using it??
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    Finish taking it apart so you can see the condition of the actual bits that do the work. Without taking it apart, you can't see if the return spring is rusted beyond hope, or if the rubber cup that pushes the fluid is beginning to perish, etc.
    • DeanR
      • Jan 2005
      • 1493
      • Finger Lakes NY
      Ken, now for the stupid question of the day. Picked up a cheap snap ring plier at Harbour Freight today for the master cylinder. Don't think I've ever had to use one before. Anyway, still can't get the circlip out. It compresses, but stays put. It almost looks like it doesn't compress enough to get free. What am I missing??
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        forget all that, return it.
        i bought a needle nose plier from sears on sale for 5 bucks and make sure it is really pointy and really slim and it worked perfect leverage and accessability!
        couln't have been eaisier...
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • DeanR
          • Jan 2005
          • 1493
          • Finger Lakes NY
          Needlenose worked great. All apart. Rubber parts look new, as does the spring. Not 100% sure which way they go back in though (they exited kinda fast). Hard to tell from the schematic. Anyone have any pics or such?
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            c'mon, it's a puzzle you can do, it's logical
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
              Press the plunger in just a bit while you work the snap ring plier. If you don't, the force of the spring keeps it jammed in its groove.
              • DeanR
                • Jan 2005
                • 1493
                • Finger Lakes NY
                mason, I think I have it, just want to make sure. It is the brakes after all. I think large end of spring goes in first, small end against plunger?
                Looking at a piture of a parts kit looks like it shows an o-ring?
                I see only the two rubber end pieces on mine, no o-ring.
                Sorry, I guess it's simpleton night!
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  iirc, spring, thin washer to protect the rubber cup, then rubber cup, , this cup seals the fluid like a toilet plunger and pushes it forward, the the large metal plunger, the other rubber piece is a seal in the middle of the rod, which is the oring, and can be removed for cleaning, then the clip, are those all the pieces?
                  i soak everything in clr comes out squeegy.
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
