Yamaha rod bearings - how do they sell them?
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    My bearings just came today from cycle-parts.com... and it looks like they sent me HALF bearings and not FULL bearings...is this right????
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    Here's one that I won on ebay after finding out this particular size is discontinued:
    http://cgi.ebay.com/ebaymotors/NOS-Y...ayphotohosting
    It clearly is marked 2 pieces for the identical part number and has both halves...
    • randy
      • Dec 2003
      • 4521
      Snow,
      According to the Yamaha fiche, the halves are sold seperately. The fiche notes that you'll need eight halves to complete the rods.
        Re: Yamaha rod bearings - how do they sell them?
        Do you need any more bearings? I have some if you should. What color would you need?
          I also have the complete set of bearings. Won it on fleabay a little while ago. I plan on using the set for winter project, but I can dole some out to get another XS running. I have the set of 8 bearings of each color. PM me if you need any.
          Ray
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            Thanks for the offers guys, I might just take you up on it after I get my #3 rod back from the machine shop Monday (left it on the piston when I thought I might be able to reuse the pistons).
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              So, it seems that I misread the almost legible numbers on the rods. Today I plastigaged into their respective places on the crank after noticing that the bearings are stamped with a code on the rod side... come to find out 3 of my 4 sets of bearings are the same size and they are D7K. The fourth is D8B. After plastigaging, the 3 D7Ks turn out to match the -40 which is also stamped D7K. The fourth is D8B but it also is within specs for the -40, though it is near the loose end of the scale.
              So, now I find that I have:
              2F3-11656-20-00 x3
              2F3-11656-30-00 x2
              2F3-11656-10-00 x2
              And I need:
              2F3-11656-40-00 x6 (Yellow)
              Anyone want to trade a few?
                How many yellows do you need?
                • Snow
                  • Oct 2002
                  • 1041
                  • Tallahassee, FL
                  DiverRay has got me covered - he's going to ship me the 6 I need and I'm going to ship him back the 7 that I've got.
                  • pac00t
                    • Sep 2006
                    • 50
                    Hi, I'm rebuilding the engine a bit. Got the cylinders slightly honed and it looks like I can put new standard rings on and it will be just at the wear limit. Cheaper than Wisco.
                    Anyway, the bike has 40k on it. Should I be worried about the bearings? I was planning on not even taking the rods off when I split the case to clean some things. (and look for my timing chain master link )
                      If it was my engine, I would check rods and main bearings, as long as I had it that far apart. If you use platigauge, it's only about one hour to check everything. Then you know if you need to replace something, or if your good. I just like the peace of mind. Don't forget to replace the springs in the starter clutch!! after almost 30 years, I know they are probably in need.
