front MC swap
  • lazer
    • 37
    • Los Angeles
    front MC swap
    Howdy All,
    Anyone know if there is a front master cylinder assembly that will fit a 79 XS11SF, without losing the brake light switch,etc?
    Any and all info would be greatly appreciated.
    Cheers,
    Lazer
    81XS11H
    why not?
    Free Shipping for Either One
    LAZER,
    I posted this reply a few months ago:
    MikesXS:
    Master Cylinder Assembly
    Master Cylinder Assembly - 16mm bore. - Recommended for late dual disc Front
    brakes on 1977-84 XS650’s or single front disc brake (1972-76 650’s). Yamaha
    OEM type. Complete with brake lever, brake light switch, banjo bolt and washers.
    Part #08-0265 $79.00 USD EA.
    PartsnMore:
    DUAL DISC MASTER CYLINDER
    Dual Disc Master Cylinder Assembly. Yamaha Style - Alloy body Master Cylinder Assembly with Lever, Banjo Bolt, Banjo Bolt Washers and Brake Switch. High Quality , Low Profile Design featuring 16mm cylinder with 10 x 1.25 threaded outlet. Fits 7/8 inch Handlebars, Accepts Yamaha Style Left Handed Thread Mirrors.
    $76.00US EA.
    Part#08-0264
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I have the above master cylinder on both my XS's. Thus, I highly endorse them.
      I personally would use them on any (dual front disc) bike that has the plastic resevoir. It that peice is broken by accident or on purpose then you no stoppie.
      25+ years in the sun had mine looking rather brittle.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • lazer
        • 37
        • Los Angeles
        thanks guys
        thanks-you guys always come through!
        Cheers,
        Lazer
        81XS11H
        why not?
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          how bout an angled one for the xj??? i have found some on mike's xs but they are for single disk. i know the xj only stops one on the front right? so would this one be ok for the xj?
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
          • pggg
            • 1609
            • NZ
            14mm cylinder is better if you've got braided lines
