Combustion chamber cake?
  • randy
    • Dec 2003
    • 4521
    I'm in the process of a valve job on Swamp Thing, I knew I had a valve seal problem years ago but just getting around to it now. Plenty of oily carbon all over the place, but there's also a hard brown cake-like deposit on the piston crowns. I was wondering if any of you know what that deposit might be caused by?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    cake
    if you can hold out a few more million miles, you'll have a nice diamond form in that muck. Just superheated hydrocarbons, probably from extra oil deposited from the seals...my2cntz
    MDRNF
    79F.....Not Stock
    • Snow
      • Oct 2002
      • 1041
      • Tallahassee, FL
      You can try placing a rag soaked in vinegar on the valves and pistons to break down the carbon without damaging anything.
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        chemicals
        I like to use methylene chloride for carbon buildup or old paint removal. It is the main ingredient to the aircraft paint remover you find at wal-mart....wear gloves and goggles....then you can brush it off and then shoot carb cleaner to take it to spotless....jat
        MDRNF
        79F.....Not Stock
        • randy
          • Dec 2003
          • 4521
          Gentlemen,
          It's not the removal, but the cause that I was asking about.
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            Originally posted by randy
            Gentlemen,
            We know that, we are just trying to get our post #'s higher
              • 7831
              Randy,
              If it's brown, it is from the gas. some brands have additives that build up quickly, and others will keep the combustion chamber clean. I've found over the years that ALL Shell gas will cause the buildup MUCH faster than other brands. It's great to bring up the compression on an older engine, just don't get it too hot. IF the carbon buildup gets too hot, you will have a BAD knock and pinging from the mixture exploding too soon. I try to spray a little carb cleaner into the carbs at tune up time. it keeps the build up down.
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                The build up is mostly the burnt oil. (at least in your case)
                I agree with Ray about the additives. Additives will also color your sparkplugs funnily, too.
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  hey, will part of a bottle of chevron techroline every now and again help keep the chamber deposit relatively free?
                  they show before and after pics and i think mercedes or porsche recommends it, any comments of experience?
                  me and planedick tunne my bike up over the weekend compression 170 across the board, valve in spec, tad tight on the ex side.001, carbs a little off snyc, timing close, runs great with idle screws 4.5 out, maybe the coils, chambers a little black...
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                    Mason,
                    Techroline as well as Sea Foam are both highly recommended for periodic maintanence of the carbs, and I'm pretty sure they assist in keeping the combustion chamber clean as well!
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      thank you,
                      Top Cat
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
