My #2 plug keeps getting carboned fouled and the bike misses above 7500 rpm.
I have performed the following:[list=1][*]Checked the valve clearance. #2 intake was at the tight end of the tolerance, so I put in a new shim.[*]I measured the compression after the valve adjust and #2 was at 135 psi.[*]I measured the resistance of the coils with the end caps off, and they were in spec. [*]Put in new NGK BP6ES plugs.[/list=1]
Is this a carb or coil problem? I still have the stock coils.
Thanks
Thanks
