I had a very interesting time at the local Moto-Guzzi shop, they deal Aprilia and Laverda also - Moto International "cogito ergo zoom"
They have an exhaust gas analyzer, and use it a lot. As Ken D. pointed out in another thread, it's only good for idle and off-idle, as higher rpms are pretty much meaningless without a load on the engine.
At off-idle (2000, 2500 rpm) the EGA says I'm right on the money. At idle, a tad lean, just a bit, turning in the idle screws just 1/4 turn made a difference.
What was interesting was that the seemingly knowledgeable wrench there said he could never figure out why people tune for plug color, that when you use the EGA, when you get it in the correct range, the plugs are almost always white. He says he only uses plug color as an indicator on two strokes, that a perfectly tuned 4 stroke motor should have white plugs!!!
So, I learned something. Problem is, I don't know what I learned
Did I learn a new (to me) fact, or did I learn this guy is full of baloney?
Input and comments, please?
He says that without any lean symptoms (no surge, goes to redline) the only way to get any better is to go to the dyno.
