Sticky Tires
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    Sticky Tires
    when someone talks about how one kind of tire is stickier than another, how do they know?
    is it the feeling and feedback of the tires giving the illusion of adhesion therefore giving more confidence in taking the turn faster?
    or are they sliding around in tires that are not sticky. and they are making that comparison.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • Hired_Goon
    • May 2006
    • 184
    • Perth WA Oz
    I think it is the movement you feel.
    For example, I have a Michelin on the back of mine and I find it gets a bit loose sometimes. Mainly with power on coming out of a corner. Was really bad when new(first 500 Km), had some big moments. Also notice if I change down while braking the little extra engine braking causes a small lockup. Get a little squeal out of it.
    This to me is not a sticky tire.
    However, it is the only one I have had on the 11, so that makes it hard to compare without trying other brands. But since the tire is new and I ride under the limitations of the tire then I can live with it.
    1981 XJ550RH
    1978 XS1100E The Wildebeast
    1978 XS1100F X Streem
    1980 XS1100G (with an E motor)(parts bike)
    Jet/Mod Calculator
    Speed/Gearing Calculator
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      Generally a "sticky" tire has a softer rubber compound on the tread. The soft or hard properties are called the tires "durometer" .
      In most cases a sticky tire will grip well but wear out soon. A harder "durometer" tire will last longer but may not corner as well. There are dual compound tires with a higher durometer (harder) compound in the center tread and a lower durometer near the edges of the tread.
      Tread design also plays a factor in how well a tire grips under various conditions. This accounts for the plethora of tread designs (slicks to knobbys) and various specialties of tires. Some work better in rain (deep grooves), drag racing (wide, flat, sticky tread), touring (hard compound), etc.
      Another factor is sidewall construction. A light bike can take advantage of a more flexible sidewall to keep tread on the ground. Our hefty XS's need a stiffer sidewall which flexes less.
      You need to decide what kind of riding you're going to do and choose your tire accordingly. I have Dunlop K491's on my E which has all the touring stuff on it. The 491's can handle the weight of the bike, provide long service life, has deep tread which is good in the rain, and is decent for cornering. My LG is set-up a bit sportier with no touring fairing, saddlebags, or trunk and is usually ridden in summer around town and local rides. I ride it a bit more aggressively and have Dunlop (404?) ArrowMax tires. They are a bit softer and the back tire only lasts about a year and a half but it allows the bike to corner faster.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        so does a softer and stickier tire tend to pick up more nails and flat easier?
        and the harder compound rejects road debris?
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
