"Where THIS man has never gone before..."
  • jimboreeno
    • 427
    • Smithville, MO
    Hi all,
    I am noticing some oil around my valve cover and am planning on replacing the gasket. While this question will seem simple to you wrench-turners, I have never attemped this and am wondering what else I should check and/or adjust while I have the cover off.
    Thanks,
    JimBoReeno
    My Ex!"Half-Breed"
    '82 XJ1100 Maxim with
    '80 XS1100SG Motor
    Current Bike
    2000 Indian Chief
    Millennium Edition
  • 81xsproject
    • 3185
    • Fortuna, CA
    Not trying to sound to "duh", but how bout the valve clearances? I also usually take the opportunity to clean and add a fresh coat of paint the the valve cover.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • jimboreeno
      • 427
      • Smithville, MO
      There really is no "too duh" for me!
      I have been reading about the clearances and shims but will have to read further in the "how to's"
      JimBoReeno
      My Ex!"Half-Breed"
      '80 XS1100SG Motor
      Current Bike
      2000 Indian Chief
      Millennium Edition
      • 81xsproject
        • 3185
        • Fortuna, CA
        Do yourself a huge favor and whatever you do plug/cover the cam chain hole with a rag. Having done it the hard way would want a valve tool if I did it all again.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          I agree that checking your valve clearances is a good udea IF you are going in there... but have you tried to simply re-torque your valve cover screws? Between contracting and expanding from heat, and the vibration of your bike, they will loosen alot of times. Also, it may just be your half moon gaskets on the right side that is leaking... they are bad about that.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Replace the "half-moon" end plugs while you're there
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
              And you can get the valve cover gasket and the half moons from PNM at the same time.
              • xj11john
                • Jun 2005
                • 440
                • Lafayette, TN
                Thanks all for posting, I'll have to do the same thing, Jimbo, maybe we can make a day of it and do em both.
                '82 Xj1100j
                "Ride for the Son"
                John
                • jimboreeno
                  • 427
                  • Smithville, MO
                  Nice to hear from you John. I tightend the bolts, several were NOT torqued much at all. So next I am going to clean clean clean. I will then check things after a while of riding to see if I do need to pull it.
                  JimBoReeno
                  My Ex!"Half-Breed"
                  '80 XS1100SG Motor
                  Current Bike
                  2000 Indian Chief
                  Millennium Edition
