79f axle holder stud broken
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    okay i checked and i actually got some good answers,
    yes i snapped the front stud, and i got it out.
    so can i just stick a bolt in it?
    some other thread, says i can put some allen cap screws, but will it allow for proper tightening?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    YES
    I have done the same thing. even installed stainless allen heads. m8x1.25 IIRC....CHOP
    MDRNF
    79F.....Not Stock
    • Dragonrider
      • 1219
      • Garland, Texas
      Make sure they are the grade 8 or equivilent. Not all bolts are created equal...and you need the good ones down there.
      CUAgain,
      Daniel Meyer
        • 5050
        With my 4-1's, I find that bolts are better than studs in at least one location because of clearance with head pipes.
        • mason79
          • Mar 2006
          • 1351
          • los angeles, ca
          i'm glad they weren't so good to begin with otherwise i prolly would have busted the fork
          torque wrench wouldn't click.
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
            • 5050
            I am sorry. I misread/misintrepreted the stud location. Disregard my post!
            • HobbyMan
              MeatHead Idiot "GURU"
              • 1801
              • Colleyville, TX
              So those are actually suds down there? I never really thought about them, though I have done my share of fork rebuilding.
              Acta Non Verba
              • mason79
                • Mar 2006
                • 1351
                • los angeles, ca
                okay i can't find a grade 8 or even grade 5 bolt
                8mm x 1.25 pitch x 40mm long
                to rplace my broken stud,
                anyone know what grade the stud was? if grade 8 would be over torqued then it would strip the fork legs instead of breaking, right?.
                is a allen cap srew a grade 8.8? will that work? and can i place enough torque on that fastener with a teenie allen wrench to spec?
                or is grade 10.9 better whatever that means,
                any suggestions would be great.
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                  With the low torque applied to the fastener, I wouldn't really worry about the strength of a bolt. The torque is only 14.5 ft.lbs. You can generate that kind of torque with just your wrist. That's about the same torque a spak plug requires, and that is for a nut on a steel stud. When you start screwing the fastener directly into the aluminum, you can easily strip the threads, so I would recommend replacing the broken stud with another stud. After all, what is the torque on the fasteners holding the covers on the engine? 7.7 ft.lbs, that's all. That may not be enough to properly clamp the axle in place securely.
