Greetings all!
In the process of exhuming a 79 XS1100 standard. Me and a friend rebuilt the carbs and they leak (Over flow) like hell. can't seem to get the float valves adjusted correctly. One adjusment they don't leak. Then, let them sit and a few minutes later....whoosh!!! The air filter housing is flooded with fuel.! He suggested rubber or plastic tipped float valves and new floats possibly made of plastic instead of brass for better regulation of fuel. I'm fairly new to this carb rebuild game and could really use some help! BTW when the carbs are not spewing up the place this bike sounds very strong! I know it's getting very clean fuel so debris clogging up the works is not an issue. I'm getting cross eyed form disassembling and reassembling these carbs!!! Any and all help greatly appreciated!!!!
Regards and thanks for a great club!
XSRIK
XSRIK
If you see any, then they are leaking and therefore are probably sinking which "could" be contributing to your leaks?
