Rear Wheel Drive Hub Nuts
  • EZMoney
    • Oct 2006
    • 115
    • Castlegar, BC,
    Looking for some values on the drive hub nuts on the rear wheel.
    There are some conflicking values depending on which drawing you look at. One drawing I have says that they are to be torqued to 14 ft/lbs and another from a Climer manual says 40 ft/lbs. I would suspect that the 40 ft/lbs is correct but I would like a second opinion if I could get one.
    Thanx
    Ed
    Ed
    78/82 XS/XJ mostly made up of parts bikes
    XS1100 SG 1980 Will restore to original over time
    Considering the purpose of these nuts, I would dare say 40 ft.lbs is correct.
      Like the ones in my avatar ? Yes, 40 ft lbs is what you want.
      • EZMoney
        • Oct 2006
        • 115
        • Castlegar, BC,
        Thanx guys,
        I knew I could count on an answer quick
        I had the wheel completely stripped for new paint and clean up the outer rim edge and was putting it together last night and ran across this discrepency.
        I have a manual for an XJ (as that is the engine I have in mine)and in it the drawing of the back wheel shows the nuts only set to 14 ft/lbs, and I also have a manual for the 78 XS and it said 40 ft/lbs, I figured that 40 was right but thought better ask the best
        Ed
        Ed
