Headlight relay...
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Headlight relay...
    I can't seem to locate the headlight relay. Does anyone know where it's mounted on a '78 E? The light doesn't come on when the engine starts and I wanted to troubleshoot the problem, but I can't locate the relay. Is it possaible it's inside (part of) the reserve lighting unit?
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
  • Kurt
    • Dec 2006
    • 248
    • Denver, Colorado
    I had the same problem with my xs750. I never found the fix for it. I just wired a three-way switch to the batt and used it that way.
    I do have a complete wiring diagram for the 11 at home. I can take a look and get back to you.
    "It is better to die on your feet, than live on your knees."
    • planedick
      • Mar 2005
      • 2068
      Wiring diagram
      I have two versions of the wiring diagram and I'm sure I can fix the problem if I can just locate the headlight relay. So far it looks like it's in the reserve lighting unit. I just need to check the input from the alternator to see if it's gettin' juice.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      • Kurt
        • Dec 2006
        • 248
        • Denver, Colorado
        yep
        • XMRGWX
          • Jan 2007
          • 48
          • New Jersey
          The headlight realy should be under the tank just behind the neck forward of the 1st cross brace.
          Long Live the XS1100
          78 XS1100E
          85 VMax
          • Goin Commando
            • Sep 2006
            • 125
            • Florida
            The headlight relay should be under the tank just behind the neck forward of the 1st cross brace.
            Yeah, what he said ^ Right in front of the fall-over switch.
            I love the smell of Napalm in the morning.... It smells like......victory
            • planedick
              • Mar 2005
              • 2068
              Found it...
              OK, I found it and according to the print the yellow wire comes from the alternator. I found only 6 - 7 volts there when I start the motor but the relay is marked 12v. Does this mean I have a problem with the alternator?
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              • John
                • 5117
                Dick, according to Randy Rago, the voltage on the yellow wire should be around 7VAC. That is the signal that controls the relay. The contacts are what's rated at 12VDC.
                • XMRGWX
                  • Jan 2007
                  • 48
                  • New Jersey
                  Don't forget the obvious, make sure you have voltage on both sides of the headlight fuse. If it was me, I would put a jumper across the headlight relay to eliminate it from the equation. Jump the brown & blue/black wires and see if the headlight comes on.
                  78 XS1100E
                  85 VMax
                  • planedick
                    • Mar 2005
                    • 2068
                    Relay diagnostics...
                    Yes, I have already done the obvious and the light works just fine. Some of you with a '78 E know that there is a light switch on the right handlebar just above the starter button. However when left in the off position it should still come on when the engine is started. I found the relay and tested it and it is NG. I opened it up and it is just a simple SPST relay which, according to the label is 12V Although I applied 7 and 12 volts both AC and DC to the coil it would not actuate. Ohm meter said there was 19 ohms resistance to the coil which led me to believe it was OK, but applied power and no actuation is a definate no good. Now I need a light relay.
                    Drilled airbox
                    Tkat fork brace
                    Hardly mufflers
                    late model carbs
                    Newer style fuses
                    Oil pressure guage
                    • John
                      • 5117
                      Dick
                      Can you find one that is controlled with the 7VAC that is supplied? I guess you could control a relay using 12VDC, and routing it through an oil pressure switch. That way the light would only come on when the engine is running, and go off when the engine is turned off.
                      • planedick
                        • Mar 2005
                        • 2068
                        Relay options...
                        I would seem to me that I could find one somewhere, but if not I could always rewind the coil on the one I have or subistute some other type. McMaster Carr will probably have several I could adapt. Probably oughta PM andreaswiess, huh?
                        Drilled airbox
                        Tkat fork brace
                        Hardly mufflers
                        late model carbs
                        Newer style fuses
                        Oil pressure guage
                        • HobbyMan
                          MeatHead Idiot "GURU"
                          • Jul 2006
                          • 1801
                          • Colleyville, TX
                          Yo should probalby contact andreas. You might be able to find a comercially available relay and just attach a resistor to two of the leads that would keep the relay closed and it would function the same. There are plenty of automotvie relays out there, just got to find the right one.
                          Acta Non Verba
