Fixed seat design flaw
  • Hired_Goon
    • 184
    • Perth WA Oz
    Well, the XS is coming up for 29 years old next month, so I set out this afternoon to fix the design flaw that has been hanging over XS1100's for 29 years.
    To get to the toolbox on mine the seat must be removed to remove the sidecover to gain access to the toolbox. So, just remove the seat????? But the spanner is in the toolbox!!! Thanks Mr Yamaha, real bright. Yes you can force the seat up to get the sidecover off but since it's now 29 years old and getting a bit rusty then the seat damage could be fatal.
    My solution:
    Went down the the pushbike shop and picked up 2 of these quick release bolts.
    Nuts were know good so I found a piece of steel and drilled and tapped some threads into them to act as new nuts. (Aluminium would possibly be better) Steel was the perfect width to prevent internal turning. The shorter the better to allow more sliding movement.
    Then it was fit to my spare bike to measure and cut off the XS (excess) bolt length. I used a few spacers to keep it out in the open for final pics, but it could be used without to conceal the catches better. A little extra length to start with doesn't hurt.
    Refitted the brackets to the seat. Note: they are only small bolts so if yours are rusty be VERY careful removing them.
    Nothing left now but to fit to the bike.
    I think it looks good and will be much better. Can finally put some tools in the toolbox without carrying a spanner in my pocket.
    Total cost: AUD $15 for the quick release bolts
    Half an hour in the shed.
    Cheers
    HG
    PS Yes I am hunting for a new seat pan to recover. May get a fibreglass one made I think.
    1981 XJ550RH
    1978 XS1100E The Wildebeast
    1978 XS1100F X Streem
    1980 XS1100G (with an E motor)(parts bike)
    Jet/Mod Calculator
    Speed/Gearing Calculator
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Very nice!!
    I don't like the bolt-on seat of the XS1100. The latch/side/flip seat of the XS triples isn't much better if you had a rack and/or trunk.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • mikeb
      • Apr 2005
      • 21
      • Joliet, IL
      Great! I have been thinking of doing the same thing for some time but wasn't sure of the thread size on the quick release. I didn't think about making new nuts. Great post.
      Original owner of 1980
      Midnight Special
      • HobbyMan
        MeatHead Idiot "GURU"
        • 1801
        • Colleyville, TX
        i dont ever have a problem because on the 80+ models, the side cover has the round holes that make it easy. Why did Yamaha even use the 78 79 mounting tabs at all. The round holes make it soo much easier.
        Acta Non Verba
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          same thoughts
          Maximan suggested doing something like this when I talked to him this past summer about the FD mod. That is a good idea and will catch on quick. I think it should be immediately put in the MODs forum.....hhhhhmmmm.......T.C.
          MDRNF
          79F.....Not Stock
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            your'e not kiddin about the rust
            yes i like the hinge with the trunk for storage...
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • malber
              • Sep 2006
              • 568
              • Belmont, NH
              The PO of my bike thought removing the seat bolts was such a PITA that he always kept them loose. I didn't think that was so safe and don't mind getting out the ratchet and extender. I also don't have a problem getting the side cover off. But the quick release bolts do seem like a great idea.
              1981 XS1100SH
                Brilliant!
                Great idea, and nice work.
                  Just one more reason to hang out at the fastener aisle!
                  • HobbyMan
                    • 1801
                    • Colleyville, TX
                    Since this is such a great idea, I vote also that it shouls be put in the mods section
                    Acta Non Verba
                    • MAXIMAN
                      • Jan 2005
                      • 1817
                      THIS ROX! This mod is definitely up for numero uno in 2007.
                      Thanks
                        Re: same thoughts
                        I think so, too!
                        POOF, it's done!
                        • Hired_Goon
                          • 184
                          • Perth WA Oz
                          Aww Shucks, Thanks fellas, I'm now in the immortal area of the tech tips. (Insert :blush: smiley)
                          On a good note, the only thing I was concerned about was them vibrating loose, but with approx 100 miles under the belt so far there is no sign of it. If anything they get tighter
                          Cheers
                          HG
                          1981 XJ550RH
                          Jet/Mod Calculator
