'Weak point' on 1980 XS11 Frame??
  • 'Weak point' on 1980 XS11 Frame??
    I've heard from a few people that the XS11's had a weak point on the frame. Anyone know if there is one (or more) where is it? From what I can see, my guess is...
    ...up and behind the airbox where the frame under the seat meets the frame that surrounds the engine.
    Let me know...
    - Rockjok talks about his broken frame in this thread
    - Lloydo had a problem with a cracked frome in this thread
    - Czekus21 had a problem with rusting at the bottom of his frame in this thread
    The search button will probably find you a couple more.
    Ken Talbot
      Here's the weakest spot I see on our bikes:
      Grey lines show the lines of our frames (back half).
      Blue arrow shows where the weight of the drivers goes, supported by triangulation of the frame.
      When you get rearward of the shock mounts everythin is just hanging there unsupported.
      Weight of a passenger (red arrow) flexes the frame downward. Add a trunk with a load in it (other red arrow) and you can see the unsupported torque on the frame past the shock mounts.
      I have read a few posts on here of frames cracking in this area and I think this is why.
      On my E I plan to run a support from the unserside of the rack/trunk to the mounting plates of my hard saddlebags.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
        definitely agree with Pat. my project F came with a bad re-weld job on the frame just rear of the seat retainer tab - but i'll be cutting that section off anyway.
        also, you can see in Pat's picture how the simple addition of the red arrows causes the rear tire to lose air pressure
          Any excuse just to show off that clean MNS Pat.
            That's special airing for a Wing type ride Brian.
              I should have used lighter arrows.
              Pat Kelly
                your rear tire pressure appears low pat
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                  weak point
                  the real weak point is the flex between the two halves of the frame that happen when you throttle it. To fix this, you can weld a flat steele plate between the rear down tubes in front of the battery... My 2cntz
                  MDRNF
                  79F.....Not Stock
                    Hey Chop, do you have a picture illustrating where this plate would be welded?
                    Patrick
                    XS11F (Incubus, daily rider)
                    1969 Yamaha DT1B
                      pic
                      I welded mine in conjunction with the monoshock point. Pg. 11 of Beggining new mod thread..
                      MDRNF
                      79F.....Not Stock
                        Ah, I see. Good idea. I also now, for the first time, understand the meaning of the title of that string. I read through it all the way trying figure out what you were begging for....
                        Patrick
                        1969 Yamaha DT1B
                        • #13
                          ice-ice baby
                          I see U live in austin.My best friend lives in austin. He said the ice storm has stopped everything there....
                          MDRNF
                          79F.....Not Stock
                          • #14
                            Frozen solid since Monday. Nothing is moving. Or, if it is moving, it's not stopping. We don't get snow here, but every couple of years we get one of these ice storms. It's even too cold to mess with my bike.
                            Patrick
                            1969 Yamaha DT1B
                            • #15
                              haha
                              now that's cold....
                              MDRNF
                              79F.....Not Stock
