next step gas tank
  • jeepurz
    • Nov 2006
    • 10
    • west central illinois
    next step gas tank
    ok scored an xs standard tank , FREEBIE, well had to trade some xs 650 parts for it. heres the plan, ive cut the recessed area around filler cap out and want to weld in a cover over that and install a flush mount cap, i removed gauge float and shaft and vent tube, if flush mount caps arent vented what will i need to do to vent tank? Im hoping there vented but have no experience with em.
    also scored a 4-1 header for 60 bucks on another forum, and wheels are getting bead blasted.
    THANKS
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    venting.
    I had to make a small pinhole in the new gas cap of the v-star tank that I put on. Now I am about(maybe) to do the same for my brand new tank for my latest chop. I remember running out/starving for gas before I put the pinhole in it....chop
    MDRNF
    79F.....Not Stock
    • jeepurz
      • Nov 2006
      • 10
      well since this is going to be a streetfigher Id thought about venting like dirbikes used to do with a hose from top of tank instead of through cap. Is your chop hardtailed or streached swingarm?
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        blue streak
        blue streak (stock soft tail) is what I had the v-star tank on before I found a good maxim1100 tank that I originally wanted. My new chop is a ???? here's the new tank, cap is on it's way too...chop
        MDRNF
        79F.....Not Stock
        • jeepurz
          • Nov 2006
          • 10
          nice tank, I didnt get that lucky on the swap, she's soakin in vinager now! with the top recessed area cut out she should be easy to clean out, did get lucky no dents.
          Im surprised the tunnel on vic tank is wide enough.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            The XS tanks (both standard and special) are vented through the cap. The tube in the standard tank is a drain for any liquids that accumulate in the recessed cap area.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • jeepurz
              • Nov 2006
              • 10
              gezz I didnt know that.thought it was kinda weird running out the back, ; I had to shave it off anyway for seat cowell.
              vinager seems to be finally workin on side is bare steel after 2 days soakin.
                One thing to look out for is that drain tube being rusted out where it passes through the tank. If that has happened, fuel will pour out that tube in the back of the tank.
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  yamaha thinking
                  yeah that was a bad design idea for the tube if you ask me. If that happens, just plug the drain hole with tank sealer putty and let dry. Also for your info (jeepurz) the R1 recessed cap is cheap on ebay and you can find a wrecked R1 tank to match the cap area dirt cheap too. I was going to do that to the V-star tank but ran across the Vegas tank in perfect shape...chop
                  MDRNF
                  79F.....Not Stock
