Hello Gents,
I bought a new mac 4 into 1; beautiful, and the foam Unifilters from JC Whitney 45 bucks for 4,
I went to 147.5 mains and 45 pilots as per the suggestion on the forum, stock was 137.5 and 42.5 pilots
mixture screw out 1.5 turns.
my engine is stock,
I lost alot of torque from idle to 3k then I feel a burst, but thats not the problem,... for now
my plugs are black and sooty when i rode it for 30 miles or so, and i did not rev past 5500 without craping out,
on my way home it would not rev past 4500 without crapping.
the petcocks are feeding fine
my bike ran fine with the stock pipes and air box , even though i did not sync the carbs, mercury is ban in California now, so that is for later ,I just did a visual, but the idle climbs to 2000k
i got home and clean the plugs and took off the filters cause i thought maybe there was too much oil on them making a rich condition.
and rode around the block, pull a plug and it had turned black, still won't rev past 5500. even with the filters off.
my float were the same as when i had the stock arrangment.
so my problem is black plugs, won't idle at 1000, won't rev past 5500
i really like the way everything looks now it just has to run.
thanks for the help!
my engine is stock,
