Hot Voltage Regulator
  • dupman
    • Aug 2002
    • 15
    • Ragley, LA
    I'm having a problem with the idle after warming up. Runs great, and idles nicely until it warms up. I noticed the voltage regulator is pretty warm. Is this normal, or should I investigate further?It has cooling fins ,so I assume it is suppose to get warm. Any comments?
    Thanks,
    Dupman
  • Mike Hart
    • 1025
    • Seattle, Washington
    Warm is okay - should be able to leave your hand on it. Yes, the heat sink is there to dissipate heat.
    Could you describe your idle problem with a little detail?
