Extending Carb Diaphram Life
  • 81xsproject
    • 3185
    • Fortuna, CA
    While I had my carbs apart to check out shimming the needles, I inspected one of the diaphrams. I noticed a worn spot where the outer rubber had been worn to the mesh. The inside was okay, for now. What I also found was that the wear spot was from where it was rubbing the part I circled in red. When I rubbed that spot with my finger, it had a little rough spot. This made me wonder about the other carbs. I found that 2 others of the four had the same issue. So, I smoothed them out with 600 grit sand paper along with the rest of the chamber the diaphram might contact. Maybe this could help prolong the life of the diaphrams, maybe not. However, at almost $100 a pop, it can't hurt.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • 80mdnt11
    • Mar 2006
    • 221
    • S.E. IL./ Olney
    Huuummmmm, Good Tip!!! What brand rubberized spray have you guys had the best luck with? Will be addressing this soon....
    Thanks
    "Elvira"
    '80 XS1100LG
      • 5062
      You just voided your warranty! :-)
      • mro
        • 4276
        • Hayward, California
        Thanks skids
        Was expecting something totally different.
        First chuckle of a verrrrry long day, thanks
        mro
        • 80mdnt11
          • Mar 2006
          • 221
          • S.E. IL./ Olney
          Yea Well, I just ended a very SHI**Y day! Don't see the Humor! Had noticed some worn/weak spots on mine last gone through. OH WELL, never mind! After re-read, does sound kinda stupid.
          Sorry 81...............
          "Elvira"
          '80 XS1100LG
          • mro
            • 4276
            That’s OK, .....your from Illinois
            Have had a few diaphragms out (all were good)
            Never noticed any wear marks.
            Could be a sign diaphragm is starting to loose its shape???
            mro
            • 81xsproject
              • 3185
              • Fortuna, CA
              Maybe, but I didn't have any wear spots anywhere else on my diaphrams except where they where rubbing the bumps that had rough spots. The one that didn't have a rough spot didn't have a wear mark. Maybe mine have had the misfortune of a heavy handed and tooled PO.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • 80mdnt11
                • Mar 2006
                • 221
                • S.E. IL./ Olney
                Left Coast?
                Well, You guys out on the left side are just a little diff. too.........LOL........Just had a bad day!
                Here is WHAT I WAS refering to........http://www.xs11.com/forum/showthread.............just bein' lazy I guess, didn't run search before typed in! ( yea I know.......from Illinois right )
                And 81, Will be checking this for prob. area......Thanks
                Also for your'e reading enjoyment found this..................http://www.xs11.com/forum/showthread...m&pagenumber=1
                Keep those Slides movin' Smoooooooooooth!!!!
                "Elvira"
                '80 XS1100LG
