Air forks and ebay accessories...
  • 81xsproject
    • 3185
    • Fortuna, CA
    First, does anyone have/had/used one of the these air for balancers? Do they make much difference? I see them come up on ebay sometimes and wonder if it would be worth it.
    Second, should I run air in my forks with progressive shocks?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    I have an air balance kit I got from Dennis Kirk. I guess it has improved the handleing a bit.
    If you go with progressive springs then you don't need to use the air function anymore (or so I've read).
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      Progressive says DO NOT use any air with the springs. The air caps for the forks are just to provide a little more pre-load adjustment.
