any recommendations as what to put in the tops of the cylinders to ease this motor back.i have used diesel on old vw motors, but i am concerned about what might effect the clutches.
possible siezed motor
Tags: None
i have been kinda sick...MMO? neither will hurt the clutches?Comment
Not gone to run it while stuck.
Leave in a few days.
Leave plugs out.
Put in second gear and rock it back and forth to un stick it.
Will probably have low compression. (stuck rings)
Several here have had similar problem.
After running a few hundred miles usually comes back up.
Compression considered good if all with in 10 percent of each other. (base line of 142 psi)
mroComment
