oil filter case o ring
  • b1rks
    • Nov 2006
    • 38
    • ontario can.
    changed o ring on filter case having problem getting it to sit in right probally should not have removed old one. but anyways any tips to resolve . thanks
    Smear a bead of grease into the groove, then press the o-ring into the grease. That should hold it in place long enough to get it seated. Also, you should not be spinning the cover more than just a couple of rotations to get the thread started. Use a socket wrench on the oil filter bolt to draw the cover up to the crankcase.
    • Hired_Goon
      • 184
      • Perth WA Oz
      I had the same problem the other day. Carefully put the new o ring in and carefully fitted the canister.
      Filled with oil , cranked up pressure, then fired up to idle. Checked for leaks and all was ok.
      Blipped the throttle and ended up with two litres of oil around my feet before I killed it.
      New oring had squeezed out the back under pressure.
      Ended up putting the old o ring back in.
      I think the new o ring was a bit thinner than the old one. It had a kink in it when I pulled it out of the box so I should have thrown it out then and there.
      1981 XJ550RH
      1978 XS1100E The Wildebeast
      1978 XS1100F X Streem
      1980 XS1100G (with an E motor)(parts bike)
      Jet/Mod Calculator
      Speed/Gearing Calculator
        You must be talking about the oring around the filter bolt's shank.
        • b1rks
          • Nov 2006
          • 38
          • ontario can.
          thank for all the good suggestions 1980 xs1100 LG MIDNIGHT SPECIAL
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Age trick
            I get the fram filters and some idiot there crams the o ring in a plastic bag and then shoves it into a corner of the box so when I get it it will not lay flat anywhere certainly not in that groove. I have found that by buying two filters and taking out the o ring from both and hang them up, next time I do a oil change the o rings have straightened out enough to use.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • HobbyMan
              MeatHead Idiot "GURU"
              • 1801
              • Colleyville, TX
              All of my filters are really old because every time I buy a bike, the PO usually has about 12-15 unused filters. That being the case, they are usually warped a lot. I just smear them in hot engine oil and se put a little new oil in the grove. As the filter housing get closer, the o-ring will find its way into place.
              Acta Non Verba
                There is a product for this problem. It's called Parker O-Lube from ParkerSeals. It's like Vaseline only a little more sticky. It won't hurt the O ring because that's what it's made for.
