Flasher 101
  • crunchbird
    • 118
    • Tigard OR
    Flasher 101
    My left turn signal flashes but never cancels, but my right turn signal cancels after a turn or after 8 or 10 seconds. I took the switch apart and cleaned it up, it seems OK and no obvious difference between left and right. I don't understand how the canceling feature works, though, which makes troubleshooting it a problem. Is my flasher unit bad? I have read here that generic automotive units won't cancel which makes me think it is a built in feature, now failing.
    Any theories on this?
    David Browne
    XS11SG Crunchbird
    XS500E
  • strom
    • 1577
    • Slovenia, EU
    Check the tech tips section... there's an article bout this stuff. Since one cancelles, the other does not, I'd say it's the switch.
    As I can remember from the article, there are some metal plates, that shouldn't.... eh, just read the article, it's good.
    It's in off-site tips... here's the link
    LP
    • crunchbird
      • 118
      • Tigard OR
      Thanks! It must be my copper leaf is bent a little, I will check it again. I didn't understand the tip the first time, but now maybe I do.
      David Browne
      XS11SG Crunchbird
      XS500E
        • 5061
        Re: Flasher 101
        Take the switch off the HB and open the housing. You will see that the mechanism is a slider that activates a "momentary" switch. It is most likely sticking on the side that never turns off. Get some electrical cleaner spray (NOT carb cleaner), cover the tank, spray it in there and work the switch back and forth. The cancelling unit is seperate and is apparently working.
