Kinda bored, so figured I would ask. Anyone got it? Seen it on an 11? Just figured I throw it out there. Can you use it with carbs?
Nitrous anyone?
Nitrous anyone?
79 XS1100 modified standard
straight pipe 4-2 exhaust
Owned 83 Honda V65 Magna
Owned 02 Vstar 650 classic
owned 85 Honda Shadow VT 700CTags: None -
I'd suspect there are a few XS11's out there with nitrous - you could probably route it in through the carb boot vacuum nipples I'd suspect1979 XS11F Standard - Maya - 1196cc (out of order)
http://www.livejournal.com/~xs11 -
The boot between carbs and head I presume. Is that possible. I know with fuel injection the nitrous is mixed w/ the air before being mixed w/fuel?"Beware of any man that owns a pig farm"
owned 85 Honda Shadow VT 700CComment
The NOS instructions for a Harley kit have a wet kit that joins extra fuel and nitrous oxide in the boot:
http://www.livejournal.com/~xs11Comment
If you put NOS in the air before the carbs, you would have to mix some extra O2 to make up for the displaced oxygen from the nos. It would make the mixture too rich without it. If you added it after the carbs, before the intake, you wouldn't have any problems. Would the pistons/etc.. get damaged?United States Merchant Marine Academy, Kings Point, NY
Acta Non VerbaComment
A property of nitrous oxide is that at about 565 degrees F., it breaks down into nitrogen and oxygen. When it is introduced into the intake tract of an internal combustion engine, it is sucked into the combustion chamber and, on the compression stroke, when the charge air temperature reachs 565 deg., a very oxygen-rich mixture results. If we add extra fuel during nitrous oxide injection, the effect is like a super charger or increasing the compression ratio of the engine. Automotive nitrous systems work like the automotive eqivalent of a jet's "afterburner" and is used for short duration extra bursts of power.
Nitrous oxide has this effect because it has a higher percentage of oxygen content than does the air in the atmosphere. Nitrous has 36% oxygen by weight and the atmosphere has 23%. Additionally, nitrous oxide is 50% more dense than air at the same pressure. Thus, a cubic foot of nitrous oxide contains 2.3 times as much oxygen as a cubic foot of air. Just do a bit of math in your head and you can see if we substitute some nitrous oxide for some of the air going into an engine than add the appropriate amount of additional fuel, the engine is going to put out more power.1979 XS1100F (runnin the wheels off it)
1979 XS650 (ran the wheels off it)
1976 CB550F (ran the wheels off it)Comment
oic
Ha, I beat a 1 word post
insert beavis and butthead remark about "nipples".
Originally posted by Snow
I'd suspect there are a few XS11's out there with nitrous - you could probably route it in through the carb boot vacuum nipples I'd suspectHome of ENIAC
Kinda like a MANIAC with 2 letters difference & a computer on boardComment
Nitrous was originally used on internal combustion engines in WW1 aircraft. The oxygen injected via nitrous allowed the aircraft to fly at higher altitudes where oxygen wasn't as plentiful.
It's basically chemical supercharging, stuffing more O2 (and fuel) that a normally aspirated engine could on it's own.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Pat and Douglas are right....good one pat to remember bout the planes too...Nos was also used in the hospitals refered to as laughing gas(different content, so dont go robbing your local ER Ward).......dont go putting a Nos kit on your xs without adding the right amount of fuel...you can port inject the Nos thru the vavuum boots but you'll have to play with the right amount of fuel to go with it.....if you dont you'll lean you mixture immediately when you hit the button or trigger however you set it up and risk melting a hole in a piston or two....experience from my drag car, but i would start by using a bike kit for a similar size bike and over size the fuel injection jets to ensure your mixture is really rich when you hit the Nos, then you can down size to suit without too much risk.....
If you intend to home make the kit I would look at port injection just for the extra fuel too standard pistons should be ok....but i'd make sure you have a good head gasket and upper cyl seals...much bigger bang means way more pressure on those stock items.
I like the term "Throttle in a Bottle!", had lots of Exp. with Nos on carsa but never fitted it to a bike..I like to know how you go should you chase the idea all the way.
Does it really need Nos you need to ask youself.....lol..1982 XS1100R
1982 XJ650
1983 VT400
1990 XVS Shadow
1983 Z1100
-I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.Comment
Since two solenoids activate 1) the Nos and 2) fuel, you would need fuel feed to the carb boots.
Drill and tap for two lines to each carb boot. Nos line to each boot.
Have one petcock feed all the carbs. Have the other petcock feed a pressure regulator and electric fuel pump that is activated by the fuel solenoid.
Hit the button and the solenoids increase the O2 (Nos) and fuel at the same time. Same set-up they'd use on a 4 cyl car.
I don't want or need it on either of my XS's....... but it would sure be fun. Either the back tire will smoke or you'll wheelie over.
If I wanted a faster bike I'd buy one rather than pushing a lead weight faster that it's designed for.Last edited by Pat Kelly; 12-21-2006, 05:07 AM.Pat Kelly
Yeah,
probably not going to do it just thought I would put it out there for discussion."Beware of any man that owns a pig farm"
