Stock airbox
  • rogueinla
    • Nov 2006
    • 18
    • North Hollywood CA
    Stock airbox
    First, let me say that I've had several xs11s over the years, and they all had Pod filters, no filters, or some combination thereof. I always liked the looks of the stock airbox, but just never had one to put on. Now that I finally got my 79 XS special figured out (and d*mn, I forgot just how powerful a smooth running 1100 is)
    I thought it'd be nice to get an airbox, because I like the look. I was in a junkyard here in Sun Valley, and found a 78 XS Standard with a primo airbox, all the hoses and fittings, a good Uni filter, and for $8.95, how could I go wrong? (btw, it's still got the gauges, turn signals, front tire, motor, tank, what looks like the stock Standard exhaust... 2 cylinders into one pipe on each side. and seat, it's in U Pick Parts in Sun Valley, if you're close, call me at 818 481-8952 and I'll be happy to tell you how to get there) Got the pieces, brought them home, and proceeded to put them on my bike. Well, now I know why all the others, including the one I have now, had pod filters. All I can say is, if anyone has a connection to Yamaha, and can get me the address of the sadistic SOB who designed this f'ing thing, I'd like to pay him a visit. It's a good thing the stock airbox looks so damn good, or someone woulda killed that sumbitch. Glad I paid attention when I took it off the bike in the boneyard, and saved all the bolts, or I'da been throwing rocks at something. It's gotta take less than the 2 something hours I spent putting it on, I hope, or no one would keep one of these after they took it off.
    Anyway, it sure looks better, but gawd.... just wanted to vent. Is there some trick to taking this silly *ss thing on and off?
    Oh, and btw, where the ***@@*I* is the turn signal blinker supposed to be on a Special? I've got the parts Standard here, and the blinker is right over the battery under the seat, mine's had the wiring butchered, the PO put automotive fuses (tube fuses spliced in) in place of the stock fuse block, so there's a rats nest of wires under the seat, but no blinker. The turn signals don't come on at all, I know there's gotta be a blinker somewhere. Anyone have a wiring diagram?
    Randy
    Price List:
    Taking it apart: Free
    Putting it back together: Cheap
    Putting it back together RIGHT: 'spensive
    Having actually work when it's done: Priceless
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Air Boxes are FUN!
    The top has to be on (loose) before the carbs go in.
    Remove the battery before removing or installing the carburetors. This allows more room to move stuff around. Loosen the top vee-bracket screws to gain some slop.
    I put the carbs on the intakes, unclamped, attach the airbox, get all the bolts started, clamp up all the rubber, tighten the airbox bolts.
    I got where I can R&R the carbs in about 20 minutes.
    The flasher relay lives right under the fuse block next to the aux. power block inside the right cover. Look for a three wire plug.
    diagram
    XS1100SF
    XS1100F
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I can get my carbs out in about 10 minutes. The airbox takes 3 minutes more.
      I've never seen whats so difficult about it.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        Just removing/installing it in the right order in relation to carbs and upper/lower box helps out a lot. It is a little bit of a pita though.
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          you get better at it, i have smaller hands that helps, if you are an ape thats bad, there is a thread here on how to remove carbs, cause that's what has to happen to get the air box in...
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • HobbyMan
            MeatHead Idiot "GURU"
            • 1801
            • Colleyville, TX
            I can get the carbs off/on in less than 5 minutes. Its all about technique. I think it is actually easy. Just make sure all the bolts are REMOVED. Then you can slide the airbox back a cm or so. I Slide the carbs in from the bottom on the left. After they are in place underneath the stacks and intake boots, I just maneuver the carbs up into position. Pu them in the intake and push them all the way in. After they are in, you can slide the airbox onto the carbs. Put all the clamps and screws back on and you are done. Don't forget all the hoses. Also, it is safer to remove the vacuum line holders from the carbs and set the clutch bracket outward so that they do not interfere of bend.
            Acta Non Verba
            • rogueinla
              • Nov 2006
              • 18
              Ok,guess I was just hamfisted putting them on, hopefully practice will make perfect, I appreciate the feedback on how to do that. Figured out the turn signals, what threw me was that the Standard has an automotive type turn signal blinker under the seat on top of the battery, why are there 2 on a standard and only 1 on a special?
              Randy
              Price List:
              • Snow
                • Oct 2002
                • 1041
                • Tallahassee, FL
                I don't think anyone has mentioned this already, but if you leave the carbs off for awhile, the boots shrink a little as they cool off and harden a little. You can sometimes help them slip on by spraying a little wd-40 in the boots before installing the carbs.
                And ALWAYS loosen the retainer rings sufficiently and get 'em out of the way.
                • Goin Commando
                  • Sep 2006
                  • 125
                  • Florida
                  Yes and your wifes hair drier helps also.
                  I love the smell of Napalm in the morning.... It smells like......victory
                  • goldcoastguy001
                    • Dec 2006
                    • 137
                    • Gold Coast, Australia
                    Yep the airbox can realllllly give you the s**ts, I skinned knuckles and swore a fair bit but pratice makes life easy.....I got it down to bout 10-15min now, bad carbs and mixtures got my practice up to scratch....all sorted now i think.....oh yeah by the way i just joined tonight hi all..... )
                    1982 XS1100R
                    1982 XJ650
                    1983 VT400
                    1990 XVS Shadow
                    1983 Z1100
                    -I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.
