Very high compression, and lean
    Dell,
    I use a single gage also with a 4 line gang valve off of a fish tank to be able to open or close any cylinder. I used a piece of PVC pipe with caps and 2 brass inserts as a dampener and my needles don't jump at all. It's ugly, and I don't think you'd need as large of a piece of PVC, but it works well.
      OOps... and here's the gang valve I use...
      • DELL82
        • 260
        • Houston, Texas
        Thanks Tod I'll give it a try this weekend.
        Dell82
        Houston, TX
        82' XJ1100J Maxim "LASERMAX"
        SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
        SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
        SOLD 82' CB450SC Nighthawk, parts bike SOLD
        • audijunky
          • Apr 2006
          • 707
          • VA
          Anybody ever try this for synchronizing
          Just a really cheap idea, I have made one but have not tried it yet.
          79 XS1100 modified standard
          straight pipe 4-2 exhaust
          Owned 83 Honda V65 Magna
          Owned 02 Vstar 650 classic
          owned 85 Honda Shadow VT 700C
          • DELL82
            • 260
            • Houston, Texas
            Steve Franklin. Do you need two of the cheap sync's to do four carbs or just two at a time? Then the two sets IE: sync #3 to 4 then #1 to 2 then #4 to1
            Dell82
            Houston, TX
              El Cheapo doesn't work!
              Hey Steve,
              Yeah, I tried that one, the fluid kept getting sucked up into the carbs! It's not very heavy, and the slightest out of sync, and it just flows right up into the vacuum port !!
              I then got the spring analog gauge, built the plenum, and did it with one gauge....cause I used a cheap plastic 4 gang valve and it didn't work, so just kept hopping from one manifold to the other, but got it done!
              So....don't bother with the fluid one!
              • audijunky
                • Apr 2006
                • 707
                • VA
                Hey TC,
                What type of fluid did you use? The site I posted is not the original one I used to build mine. The one I used said to use two stroke motor oil. I think it is heavier than the fluid this site suggested. Do you think that would make a difference?
