help!!! idle screws
  • joe smith
    • 31
    • yakima
    help!!! idle screws
    I need to get some ideas on these idle screws that are broken off and stuck. I have tried to get these things out using all the techniqes that are posted on this sight. I am letting them soak in liquid wrench right now!!
    Any suggestions will be appreciated
  • dupman
    • Aug 2002
    • 15
    • Ragley, LA
    I had the same problem, I tried holding the push pin with the needle nose vise grips. I ended up buggering up the inside of the carb throat. I used a dremel and wore the inside until I could diferientiate between the carb body and the brass tip, and then used the push pin tapped with a wooden peg. I almost gave up, but got radical. It finally came out. Good luck, let me know how it turns out.
    Dupman
    • joe smith
      • 31
      • yakima
      Yeah, I have done a number on the throat too. Not as bad as I could. It is gonna be a bugger to get them out but I will keep on trying. I think if I can find some vice grips that are small enough I will be able to hold a needle and tap them out!! I'm done for tonite though. The struggle will continue tomorrow!
      • joe smith
        • 31
        • yakima
        UPDATE!! Started in again this morning on them and no luck, so being a realist decided that these idle screws beat me I took them to my local machine shop for help. The guy says it shouldn't be a problem and to call him at 3. I called him at three and he says that he is having a problem and that they probably wont be ready till Monday!!
        At least it makes me feel better that a guy in a shop with all the little tools is having a problem!!!
