I just got back from Succubus' first significant ride. It was not overly extensive, maybe 10 miles. I was just trying to find out how everything was fitting together. Overall the bike runs pretty darn well, but I have discovered three issues:
1. In first gear, coming off the line, the bike jumps and rattles soon after the clutch grabs. It almost feels like the front end is jumping up and down. It smooths out after I'm moving and hit about 2,000-2500 rpm. I suspect it is the God-Knows-how-old clutch plates, but it doesn't really feel like a clutch slipping. It feels like the front end jumping around. It smooths out as the bike accelerates. The bike also grabs well when I pound it in the other gears. Second gear is very strong.
2. The bike does not consistently return to low rpm on its own. It will stick around 3,000 or so - it's hard to tell the way the tach gauge jumps around. My first suspicion would be throttle cable, but the throttle seems to move smoothly and the return springs on the carbs are strong. The throttle stop screw doesn't seem to addess the problem. If I back it off the bike just drops to lower rpm when it finally winds down. Vacuum issue?
3. Succubus doesn't always want to downshift to second and first gears. Sometimes it's fine, sometimes it seems to bottom out on third. It upshifts great and downshifts from fifth to fourth to third just like it is supposed to. I can get it to downshift if a turn off the bike and mess with the shifter. Could this be related to issue no. 1 or am I looking at a tranny problem?
Suggestions on any or all of these issues would be appreciated.
Patrick
Patrick
