I'm about to burn this bike...
Soon as I fix one thing, something else comes up. Going back to my previous post, #2 was running black, maybe even wet. Had a look at the electrics, everything seems to check out...EXCEPT, the little magnet running inside the pick-up coils. Its dancing away much better, maybe a bent bolt etc. was maybe losing signal when the revs picked up.
Right, replace pickups with set bought off e-bay for spares. Its not 100% the same, but everything fits. Fix broken wires X2. Get around 700Ohm on both sides. Replace jets with 137.5's, float level to 25mm. (Everything now std, except 4 in 1 and giant hole in airbox)
Everything being equal, it should now run fairly well??? Wrong!
Starts up reasonably easily, runs rough for a while, and did not want to rev past about 6K. Take of airbox, goes to maybe 7K. (OK, running too rich? - Carbs off again, floats to 28mm)
(Neighbours looking over wall to see what the hell is all that noise!!!)
Back on again, still only revs up to 7K, and battling to get there...
Grab a beer and smoke and resist temptation to drop the match into the tank...
Possible theories??
1. Carbs way out of wack (Highly unlikely. I can now take them of, strip down etc with eyes closed and one arm tied behind my back!
2. Timing is way off - May be the other pick up coils send the signal differently? (I put them in on exactly the same markings as the old ones)
3. I have not checked the gap between the pick ups and the signal 'thingie' (BTW what is it called?) Could it be to big, thus losing ability to create a signal when the revs get higher?
Must get it running properly this week. Next weekend is the toyrun and I dont want to miss it!!!
Thx guys!
1H
Possible theories??
Thx guys!
1H
