Hi! This is a great site. Thank you to those who host it and those who have added so much information. I've been reading through for the past few months as I have been trying to get my first XS1100 running. I've been making decent progress (although at a rediculously slow rate) and have gone from a completely dead bike to being almost road worthy. However, I'm now stuck and could use some of your collective wisdom.
First a little history: I have an '80 SG with ~20k on it. Everything appears to be stock. It sat out in the rain for a couple of years before finding its way to my garage. I've torn the carbs down and triple cleaned them. Put carb kits in, replaced needle valves and seats. Replaced the pilots (42.5) and the mains (120 on 1 & 4, 110 on 2 & 3). Set the float levels, per the manual, and then confirmed that the fuel level is ~ 3mm from the top of the bowl when the carbs are in place and the bike in on the center stand. Pilot screw O-rings were in pretty bad shape so I replaced them as well and have the screw set to 1.5 turns out from seated. Pilot screws all still have their needles and the openings into the main passage make a snug fit. Slides, and diaphrams are in good shape. Emlusion tubes are clean as are the needles but I haven't put new parts in. Needles have only one setting option. Air jets appeared to be in good shape. Found broken pickup wires and replaced them. Compression seems a little low (~120psi) but it's fairly even across all four and I'm hoping it will come up once I can get some miles on the bike. Synched the carbs at idle. Checked the carb mounts by spraying brake clean on them and didn't notice much change in idle (maybe I wouldn't get much if running rich?).
Bike starts readily and won't run without choke. Idles okay when cool (first off of choke) but won't idle at all well when warm. Really gutless at any time from idle to ~3000 - above that though, it really screams (can't wait to get it dialed in). When I bring it back from short trips, the plugs are carbon fouled.
From what I've read here, these symptoms point to the pilot circuit. However, the passages are clear, the jets are new (from Mike's XS), and tweaking the idle screw doesn't seem to improve matters much.
Anyone have any ideas???
