im about to blow up the bike
  • tjfisher30
    • 79
    • orlando fl
    ok i can get her to run right i can get the carb right went to pod filters jet up to 115 mains will run to 4 grand with a rag tyraped it the carbs but put the filters on with or with out tc stacks and she will not run what the h@#$ am i doing wrong it was out of time on the cam got that right now still runs to 4 grand with rag but no go on the filters i can get her right this SUCKS BAD
    i need help bad
    80 xs11 sg
  • randy
    • Dec 2003
    • 4521
    Some pod filters have a protruding ridge inside that restricts the air flow. I beleive T.C. posted about this sometime last year. Do a search. And, take a look inside your filters.
    • tjfisher30
      • 79
      • orlando fl
      ya i did that T.C. stacks to fix it but still no go
      80 xs11 sg
        • 7830
        double check the float height. I would set it about 3mm off. That is to say, have the fuel level down about 3mm below what it is. If you have a LOT of restriction from the pod filters, you will be pulling a LOT more fuel through the carbs.
        I would also double check the clearance on the vent holes at the intake side of the carbs, and the carb main vent, if they are the early ('78,'79) carbs.
        Ray
        • tjfisher30
          • 79
          • orlando fl
          so your saying set them to like 25 or 26 mm or 21 or 20
          they are at about 23 mm now . and putting on the pods would make it more free folw air or am i wrong right now im so confused now
          80 xs11 sg
            To me, it sounds like you are running way lean. Your bigger main jet won't come in to play at start and idle. Have you cleaned the little jet in the bowl of the carbs? It sounds like even with a rag on the end... it revs up to 4 grand... lean (Or carbs out of synch) By puting the filters on, it makes it even MORE lean than the rag by flowing the air even more, and is simply too lean to run now?? Just a guess. You have tried to start it with full choke haven't you?
              A Recap is needed?
              Hey TJ,
              We need a recap on what you have done!? Also, you have an 80SG, possibility you have one of those funky carbs built more like the 78-79 series with the shared pilot/main tower tunnel, vs. the true 80-81's that don't share fuel between the pilot and mains, and so use smaller jets?
              IF yours is the earlier style carbs, then the 115's are way too small of jets, with the shared jet tower tunnel, then you would need at least a 137.5 jet, and maybe even larger due to the pipes and intakes!
              What do the plugs look like? IF they are bone white, then you are definitely lean. IF they are black and sooty, then you are rich.
              I am "leaning" towards Tod's impression, that you are lean, but we need to know for sure what style your carbs are.
              • tjfisher30
                • 79
                • orlando fl
                it runs good at full choke but one hit of the throttle it dies , T.C. i have clean the carbs and did a rebuild with another set but i really never looked for the tunnel between the main and the other on the tower i will look tomorrow i need to look through the main on the tower right thats were i could see the port ?
                80 xs11 sg
                  TJ,
                  Here's a couple of photos, first one is a 79SF, shows the threaded pilot jet tower for threaded cap screw plug, and the tunnel going to the main jet tower.
                  This next one is an 80SG, smooth bore pilot jet tower for RUBBER plug, and tunnel(red arrow) going to main jet tower. The main jet is the wrong size!
                  Saying that it will run with the CHOKE also hints to being too lean!
                  • tjfisher30
                    • 79
                    • orlando fl
                    no tunnel so far
                    ok well the 4 spares i have off the bike do not have the tunnel between the main and the pilot tomorrow i will check the others and for running lean that would mean i should set the floats lower they are at 23 mm i need to out then to like 22 or 21 right and try that unless i have the tunnel then i will need plugs and larger mains
                    80 xs11 sg
                      Okay, the spares didn't have the tunnels, so they should have had the smaller jets. You said you had rebuilt yours with parts from the spares. IF your current carbs have the tunnels, and you used the jets from the spares, then yes, you are definitely too lean, and larger jets and pilot plugs are in order!
                      I hope you're on the right track!? T.C.
                      • audijunky
                        • Apr 2006
                        • 707
                        • VA
                        Have you inspected the spark plugs yet? even if you only run it for a few minutes they should give you some kind of indication.
                        79 XS1100 modified standard
                        straight pipe 4-2 exhaust
                        Owned 83 Honda V65 Magna
                        Owned 02 Vstar 650 classic
                        owned 85 Honda Shadow VT 700C
                        • tjfisher30
                          • 79
                          • orlando fl
                          ok pulled carbs off no tunnels so this weekend i will clean them again and inspect everything what should i pay close attiention to ?
                          80 xs11 sg
                          • pggg
                            • 1609
                            • NZ
                            There's a million different opinions on reading sparkplugs, for me it's ignore the insulator color and instead look at the bottom ring of the plug, I mean the circular face at the bottom of the spark plug threads, if it's either smooth, shiny, clean, or bare metal, the mix is too lean. A thinnish film of carbon is good and pretty much right, and that's pretty much the same coating as you're getting on the valves and combustion chambers. Too thick and obviously too rich.
                              Okay TJ,
                              No tunnels= later model carbs, stock jets were 110-120 depending on whether you believe the books. I had found 110's in all four of mine. I went up to 117.5's, but now on a recent rally, fellow Xsive riding behind me smelled raw fuel? I haven't checked my plugs yet.
                              If it will only run up to 4 grand, which is where the mains kick in, then still sounds like fuel starvation, so going back thru the carbs is a good thing. Did you remove the main jet nozzle/ and ensure the holes are clean/clear? Are your vacuum diaphragms working properly, no holes?
                              Have you checked the vacuum advance module under the left timing cover for proper operation? Timing plate rotate easily, not getting hung up? Vacuum line good, no leaks. Similarly, no leaks around intake manifolds, vacuum synch ports-rubber caps? No vacuum leaks around butterfly seals?
                              You might need larger mains, but even with 115's, it should rev higher than 4K? I think other things are holding it back!?
