This probably sounds like a stupid question, but what is size of this? I'm talking about the rear cotter pin. I got all the way to VIP without realizing that they come in different sizes.
Cotter pin
If your talking bout the cotter key used on the rear axle nut..............use what fits, not a critical thing.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
WOW That's one heck of a cotter pin. I take it you mean 3/16 X 2. I think I have 1/8 in mine. But like moto says...use what fits.Originally posted by John
A 13/16 x 279 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
"Welcome back Cotter-pin."
It's nice and aesthetically pleasing if the pin fits tight and doesn't wiggle around. Most bikes doen't even use pins... relying instead on the friction of the nut and washer from allowing the nut to back off.
Like the others have mentioned, as long as there's something in the hole to stop the nut from loosening, you're OK."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
Just think what could possibly happen if the nut came off. That is why cars use them on the spindle holding the drum/disc on. As long as it fits and won't come off, it will work. I normally get the long ones so that I can use them on other things too. Just cut them to length. I must admit though, I have caught myself reusing them once or twice.United States Merchant Marine Academy, Kings Point, NY
Acta Non VerbaComment
Ahhhhhhh, The Good 'Ol Cotter Pin
Oh Yea, Cotter pin, saftey pin or saftey wire. Was racing indoor flat track on bikes in Ohio some many years ago.....
Was lining up for second heat, trying to find the sweet hole shot spot. Guy next to me bumps my arm & points at my front axle with the nut laying on the track!
( Yea I had swaped front wheels in between heats, better bite on the GoodYear) Pit hand came with wrench & cotter pin in hand! That could have been BAD!
Since then, racing, dayly ride or cage....... if it is criticle....cotter pin, saftey pin, saftey wire or lock-tite even if it doesn't need it!
"Elvira"
'80 XS1100LGComment
Re: Ahhhhhhh, The Good 'Ol Cotter Pin
Yeah, but you have to remember to do it!
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Safety Note ??
As tempting as it might be, if you do not have a cotter pin, do not use a finishing nail in its place. I am not sure why but I have been told this is not very safe practice.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
A finishing touch!
Only if the finishing nail isn't the right diameter, too small which might allow the castle nut to spin past it? Also, the heads are not very large on finishing nails, again, it might slip thru and out?
I would think a common nail with larger head would be a better quick temp fix, but unless galvanized, would also rust soon!
T.C.T. C. Gresham
I use a carriage pin. You can reuse them....
PatrickThe glorious rays of the rising sun exist only to create shadows in which doom may hide.
XS11F (Incubus, daily rider)
1969 Yamaha DT1B
Five other bikes whose names do not begin with "Y"Comment
OK, I'm stupid but us New Orleans boys are still alittle goofy after Katrina. What is a carriage pin??
Succubus, I'll probably know what it is when you tell me but then we have funny names for things down here.
Median is a neutral ground, sidewalk is a banket, balcony is a veranda, French bread is...well, French bread..
Mike Giroir
79 XS-1100 Special
